Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washmachine F11Code
My wash machine is giving an F11 code with around 10 minutes or less left in the cycle every 3rd or 4 wash, when set to he normal cycle. I ran the trouble shooting test and everything checked out ok. I followed your advice and concluded the CCU was bad. However, when I run the wash machine on any cycle (heavy duty, bright whites, delecate..) except normal, I do not get an error code. This has caused me to question if it is the CCU.
  • 2,272 Answers
The error code F-11 on your washing machine means:--
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
both this parts needs to be checked.
You will have to check the following to confirm where the fault exactly is:---
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU).
Check the Drive system for any worn or failed components.
Check MCU.
Check CCU.
Check Motor.
Check Wire Harness.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 12, 2010
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the code F11 mean?!
This information is taken directly from the Whirlpool trouble shooting guide we found on our Duet Sport. I quote: "The motor control unit has internal failure; repeating under or over voltage, or over current conditions." Possible Causes/Procedures 1. Unplug washer or disconnect power. 2. Check wire harness connections between the drive motor and the motor control unit. And between the motor control unit and the central control unit. Check the motor and do a continuity test. 3. Plug in washer or reconnect power. 4. Check the motor control unit by by looking for operations of the drive motor. 5. Check the drive motor for powered rotations. 6. Replace the motor control unit.
As previously stated, this is quoted directly from the guide. Hope that helps.
Feb 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Quits in cycle and flashes F11 or FdL
From Catriver/fixya, this site.
F11 is a serial communication error. Communication between the central control unit and the motor control unit cannot be sent correctly. Possible solutions: Check the harness between the two boards for loose connection. Driver motor, main board or motor control board may be bad. I have come across a number of these with loose connections and bad main boards. Put it into a test by pressing drain/spin on the left side. Then press the spin speed button on the right until no spin is lit. Then press the pre-wash button on the right 4 times until 00 comes up in the display. You are now in the automatic test mode. Let it do it's thing about 15 minutes and see if the error comes again.
The dl means doorlock. (F=fault) These machines are notorious for bad solder joints in the main control board in the door lock circuit. You could have a bad door latch but I doubt it. You can keep trying to start it and sometimes it will work and sometimes not. Remove the top of the washer. It is held on by three screws at the rear of the top. Slide back and lift up.
You will see the control at the top rear of machine. There are two connectors that plug to the board with pink wires. The board will be marked dl1 and dl2 where they plug in. Wiggle these connectors and try the machine again.
If your machine is less then 2 years old the board may still be covered by warranty. Check your owners manual for details.
Mar 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washing machine throughs out a FH code
FH is a water inlet related issue, make sure your cold water supply is working correctly, sounds as if its trying to rinse(cold water) and has no water to do it
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F11 Error
probably bad control bd remove top control mounts to rear rail ck all wiring to control first just f11 usually indicates internal control failure
Nov 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Unlock Locked door on Whirlpool Front Loader
heck pump watch for codes or numbers like 11 munites is code f11 .if this does fix its your ccu board top back for f11 code."less soap plz"
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
117 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
