Question about HP Pavilion zd8000 Notebook
Hp pavilion zd 8000 asking for power on passworrd
Pc black screen and asks for password, where I can find that one? thank you
  • 4 more comments
  • makres Jan 30, 2009
    yes it is mine computer... and today I was working and then my monitor got all black and then when I restart pc ... it happened.. I cannot go to setup menu.. when I start pc it asking for password .. thank you
    I cannot normally start up without that password.. maybe I can found it somewhere on pc or in documents?
    I never lend my pc to anyone...
    oo and I saw that it says that bios shadowed....
  • rosc_18 May 11, 2010
    maybe someone sets password on your pc or you forgot your own?
  • Randall  Trahan
    Randall Trahan May 11, 2010
    The password on the black screen when you start up is called the BIOS password. It is normally set-up to keep someone from getting on the computer when they are not supposed to. Is this your computer? Did you lend it to someone recently?
How do i get the hotkeys to work on a HP zd 8000 laptop
If you have the remote for the HP Pavilion zd8000 you can use that to switch if the keyboard is faulty.
Feb 05, 2012 | HP Pavilion zd8000 Notebook
Help!!!!
The "On" button is located on the left top side of the keyboard - it is the button that has a circle with a vertical line through it.
Apr 04, 2009 | HP Pavilion zd8000 Notebook
OPENING THE CASE FOR HP PAVILLION ZD8000
Hi all
I have made another guide than the one that was removed from the net.
cleaning your hp zd 8000 in 9 easy steps... with photos and detailed a description.
how to clean a zd 8000 notebook
here is the link : http://www.realsancristobal.com/myguides/how_to_clean_a_hp_pavilion_zd_80.htm
hope it helps someone out there
Peace
Nov 10, 2008 | HP Pavilion zd8000 Notebook
HP Pavillion ZD8000 display problem
Before you invest any further, try the lcd inverter http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/ I have seen them for real cheap. If you take off your bezel cover underneath the display you'll find the inverter9147480.jpg or if necessary you can get a tech to help install. Usually theres a series of beeps when you get a blank screen. Hp pavilion laptops also get hot on the keyboard after a while from long term use and zd 8000 came out about 4 years ago so the display should be a pretty good looking glossy screen. Those are nice laptops to work with by the way.
Oct 12, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000
a power surge could have caused this problem, as you so rightly assumed. motherboards-cpus et,c. are prone to fail or malfunction. even with static electricity.
it could also be a sign that, the tft ( screen ) has faults or the cfl (tube) or inverter have suffered damage.
Mike @ compurepair.
Jun 10, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
198 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
