Question about Karcher 2500 PSI Pressure Washer
Honda power washer dont have presser
I have a honda power washer an i have to keep taking the tip off for it to work
  • doncubberley Feb 10, 2009
    I have pressure only if I take the tip off run watr through a few times,reinsert the tip and pull trigger as soon as I let off I have to repeat that process.I allready replaced trigger and hose. I disconnected pressure hose turned water on and kinked hose several times and pressure from pump seems to work fine.
  • 1053 Feb 13, 2009
    I have the same problem I think. My power washer works find for a while, then I have little pressure coming out. When I take the tip off and put it back on it works fine for awhile I have pressure. When I put the rotating tip on it works fine as normal. Can you help me out
    Problem Solver:
  • 12 Answers
Your unloader valve is stuck in your water pump. Remove it, lube the top o-ring with silicone grease. Then reinstall it. Use pump guard additive to prevent this problem from reoccuring.
Posted on Apr 03, 2009
I have a Honda 5 hp XR2600 presser washer, I have trouble keeping it running without the choke on. It starts right up, but it need the choke on to keep running.
I would try empting the gas out of the tank just to make sure you don't have some water in the gas. If that doesn't help you have a carburator that needs to be cleaned or maybe rebuilt.
Sep 30, 2013 | Garden
My honda gc 160 pressure washer i have to take the tip off the wand to get it to get to have pressure.
With the tip removed you have pressure? or you have flow. Usually, with no tip you have very little pressure with lotsa flow. Sounds like tip clogged up. Have you tried other tips? If you hold the tip up to the light you should be able to see through the oriface.
Jun 27, 2010 | Honda 2500 PSI Gas Pressure Washer
At what period of time parts like chain, spark plug, battery, airfilter , brake shoes etc., need to be changed in order to get proper mileage and pickup. problem: my motorcylce gives around 45km/ltr. are...
Keep the tyres at the correct pressure this is the main cause for mileage problems.. Chain keep oiled so there is low drag, plugs as per book, ari filter dont let it get too dirty, brakes make sure there not over adjusted and causing drag, battery only if its discharged all the time it can take some power. oil keep it clean.
Jul 01, 2010 | 2005 Honda Unicorn
Pressure washer worked fine and suddenly no
If you remove the tip, will it work? If so, unloader valve is sticking and needs to be removed and lubed with lithium grease.
Jun 29, 2010 | Honda 2500 PSI Gas Pressure Washer
Nozzle is dirty. Use small diameter wire to clean out nozzle.
Sep 09, 2009 | Honda Pressure Washer PSI 3000
Wont pull detergent
problem is that u have to use with lowest pressure i believe black tip
Jun 20, 2009 | Honda Maxus Pressure Washer MX5222
Need throttle sping help
Take spring to local harware or home improvement store (Ace, Lowes, Home Depot, etc.) and get a similar spring.
Jun 07, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
Apr 09, 2009 | House Brand Garden
Karcher 2500 PSI Pressure Washer Logo
226 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
