My 53 plate citroen 14 hdi heater blower will not switch off and is running on full speed continuous even when digital control shows fan speed on low does any one know what this fault could be. thanks
Have a load test done on the battery as the glo-plugs should get very hot very quickly. Diesel engines have to have a high rpm crank speed or they will not start and will leave unburnt fuel in the cylinders ( wet glo- plugs). Every indication is that the battery is flat or is not the right capacity for the car.
folks out side UK have no clue what my51 plate
we use the VIN to learn what year it is. and engine,and what country sold to.
is dash heater blower dead? on even high? speed?
test 1 of 10 . or so.
test 2 does pcm scans show ect at 180 to 200f temp?
google 200f to C and get your answer.
test 2 do both fire wall hoses, to heater core feel super hot, hand flays off?
i not both the core is clogged
if all hoses water feel cool they are and thermostat bad or missing
Hi all. Yes this is a very common issue. 2 distinct issues in fact are common with the aircon.
1 you get fan on certain settings only. This is the resistor gone and johnjohn2 has identified the fix for this above. This is usually (although not always not intermittent and so you will usually lose all other settings over night and they don't come back
2 you get no fan activity at all. This starts to happen intermittently and then gets more frequent until the fans won't work at all. The fix for this is expensive through Citroen but cheap if you get the part off ebay. It is the ignition switch cable which has a fault. A very common issue. You need to remove the ignition switch and replace the cable from it. Work is not long but plugs can be tight and fiddly.
here is the link for the part http://www.ebay.co.uk/itm/Ignition-Switch-Cables-Wires-PEUGEOT-206-CITROEN-XSARA-PICASSO-Lock-Barrel-Plug-/121038091531?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c2e6eb50b
good luck
Before removing the heater switch on this 2006 citroen hdi I would first have the blower motor checked and the most common reason for this and other blower problems would be the blower resistor.
Your blower works on and off at times, first locate the blower motor and the resistor. the blower motor is located on the heater box, look under the pass/side of the dash, you may have to remove under dash cover to see blower. When you have located the blower now look to the side on the heater box, there you will see a connector plug, it plugs into a connection on the heater box, this will be the resistor, the resistor slides into heater box and the end of it bolts to box to hold it in place and then the connector plugs into it, if you can not locate it then follow wires that plug into blower , follow wires back they will lead you to resistor, next time blower does not work wiggle connector to resistor and see if blower turns on, if it does then resistor is the problem. also unplug resistor plug at resistor and check for any burning of connectors at plug and inside resistor.
I would bet its a bad resistor or the plug is brunt due to high draw from bad connections, if plug has burn damage to connectors then replace the plug along with resistor.
May not be the heater. Could be you have something burning up and this is causing the heat to be dispersed in to car. If the pulleys all work on one looped belt, see if one of the pulleys is locked up (not spinning). This will cause the belt to burn and may cause engine to overheat. What type car?
thank you i will check garry
Exactly the same problem on our C3 1.4HDI 16v 52 plate??
