I have an MX310 Printer but my manual is at another location. Where is ink cartridge and how do I access it for changing?
    President:
  • 1,901 Answers
Click on this link:
MX310 Support
On the Support & Service tab, type replace ink cartridge in the "Please enter your question" bar.
Click on "Search"
There will be some links appear. One will say "How do I install ink cartridges.?" Click it.
There will be step by step instructions with pictures and animations to guide you.
Thanks for using fixya.
BTW, you can also download a manual while you are on the site. Click on the Drivers and Downloads tab.
Posted on Jan 30, 2009
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
Trying to change from black and white printing to color on canon mx310 please please help
Go to Cannon My Printer file, Click Printer Settings, Click Maintenance Tab, Click Ink Cartridge Settings, Select the ink cartridge for printing, Hit ok.
Apr 02, 2010 | Canon PIXMA MX310 All-In-One Printer
How to change ink cartridges. canon mx310 printer
Raise lid to expose cartridges...if they are not accessible, then reset power...off, then on...the cartridges should "cycle" to left side...if not, turn power off and you can manually pull the cartridge "case" to the far left...push down on a cartridge, then pull out...replace with new cartridge by inserting into slot, then pulling up on front of cartridge until it clicks into position...repeat with second cartridge...print test page...should be fine...
Jan 21, 2010 | Canon PIXMA MX310 All-In-One Printer
I have never had to change the ink cartridges till now and can't find the manual. The site says that they don't have a manual for the MX310 and I can't figure it out.
Hello !
To change the ink cartridge(s) in your printer,
Lift the scanning unit (printer cover) with both hands.
Pull the scanning unit support down into place.
The cartridges will move into place.
Remove the cartridge.
Take the new cartridge from the package.
Remove the strip from the cartridge without touching the metal back.
Insert the cartridge.
Hope this helps.
Oct 04, 2009 | Canon PIXMA MX310 All-In-One Printer
How to change the ink in a Canon PIXMA MX310?
  1. Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
May 27, 2009 | Canon PIXMA MX310 All-In-One Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Alram light
Did you replace the Black ink cartridge or the Color cartridge, or did you replace both?
Facing the front of the Canon Pixma MX310, did you install the Black ink cartridge to the left side, and the Color cartridge to the right side?
Do Not reverse how the ink cartridges go. Do Not install a Black ink cartridge, in the Color cartridge holder.
If the Alarm light came on, check to see if you have an error message in the LCD. (Not trying to insult your intelligence. The LCD is the little rectangular Liquid Crystal Display on your Pixma MX310 Operation Panel, to the left of the numeric buttons)
Do you have the Pixma MX310 On-screen manual?
Start>Hover on All Programs>Canon>Pixma MX310>On-screen manual
Click on the Troubleshooting heading.
If you have an error message code, click on the heading ->
An Error Message is Displayed on the LCD.
Also suggest you click on the heading -> Problems Sending Faxes.
See if the information provided has a solution to your problem.
Apr 22, 2009 | Canon PIXMA MX310 All-In-One Printer
How do I change the ink cartridge
do u have a manual of your printer see in manual
Oct 24, 2008 | Canon PIXMA MX310 All-In-One Printer
MX310 error code U163
Can you tell me, have you replaced the empty tank with a full one? And, have you manually reset the ink level function by pressing Stop/Reset for a full 6 seconds (one second longer than described in your manual?)
If you have, and you still see the ink cartridge light flashing, does it flash every second or every three seconds?
The contacts for the ink cartridge are easy to contaminate by accident. Sometimes wiping the contacts off with alcohol will clean them enough for the ink level to be recognized.
Now, and yes, this is a common problem. Press and Hold the Stop/Reset button for 6 full seconds again after cleaning the contacts and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Please advise me of your results. There may be a more complex problem involved and it is important to have the necessary data in order to get you back to working again. Okay?
How long has it been since you purchased this printer?
Regards,
Worldvet
Oct 15, 2008 | Canon PIXMA MX310 All-In-One Printer
41 people viewed this question
jasbo
jasbo
