Question about HP OfficeJet 7310 All-In-One InkJet Printer
Is there a manual that shows me how to open up an hp 7130 to clean the glass?
    Genius:
  • 2,120 Answers
Lift the top cover up.
Posted on Jan 31, 2009
HOW DO YOU REMOVE THE GLASS ON A HP OFFICEJET 7130 PRINTER I HAVE REMOVED THE SCREWS BUT THE COVER WON'T COME OFF.
Gene,
There are a couple of "hidden" attachment points which hold down the top bezel and glass. You can see step-by-step photos on disassembly of the scan bed that will show right where they are at http://www.fatrcat.com/hp7100/scan_head.html
Mar 22, 2012 | HP Officejet 7130 All-In-One InkJet...
Canon NP 7130 F copier Copies are dark in some areas and light in other areas. We no longer have a service agreement on this machine. I cleaned the feeding roller in the ADF, new toner in machine,...
Enter in service mode and do an cartridge adjustment. Maybe the toner is not uniformly distributed in cartridge. Also you can search on internet for service manual, this may help you a lot.
All the best !
Dec 03, 2017 | Canon NP 7130 Black and White Copier
How do I remove the glass in an Officejet 7130. The glass is cloudy inside.
Not easy, quite a pain actually and far too long for me to type out, in short all covers off, doc feeder off, all conectors and earth straps that go from top to bottom must be disconnected, two main screws R+L hold the top half to the bottom, then the top slides forward and off from the base.
Then once you have two units the printer and the scanner, you can remove operations panel cover, remove securing screws in underside of scanner ,,,,,
One can just get the little glass out very easy one screw and no splits, but it is near impossible to clean the glass properly, also if you are brave enough to split the unit, you best be doing the mirrors because all go yellow and cause scanner failure.. I've done this probally 6 times, I quote 2-3 hrs and perswaide people it aint a good idea to fix these scanners,
the best easy fix is forget the fog on glass, it's normally not the real issue, its the mirrors near the lamp that are the dirty ones, causing scanner to dance and not come to ready and throw errors,
open **** glass then by turning power off and on over and over, one can move the scanner ever so slowly towards the other end of the glass do you can get to mirrors with a cotton bud, the on off way works but I myself grab the belt with plyiers and manually drive the scanner to the other end, if on the other hand the scanner works stop it mid print then go at it... cheers sorry no simple answer cause it just wasn't made to be got at.. don't have to tell me I know....
Nov 05, 2009 | HP Officejet 7130 All-In-One InkJet...
How to clean the sanner glass
You can use a soft lint free cloth to wipe out the scanner glass. You can also use the regualr glass cleaner but make sure you dont use too much of it.
Aug 11, 2009 | HP Officejet 7130 All-In-One InkJet...
NP 7130 Black and White copier
clean the scanner glass. There is probably a tiny dot thats the culprit.
Jul 06, 2008 | Canon NP 7130 Black and White Copier
Officejet 7130 problem with scan
Try cleaning the white calibration strip under the scanning glass (requires technical knowledge).
Try this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01150111&lc=en&cc=us&dlc=en&product=91466&rule=23549&lang=en
Dec 28, 2007 | HP Officejet 7130 All-In-One InkJet...
HP Officejet 7130 "Scanner Failure"
Scanner failure usually means you'll have to replace the entire scanner unit.
When the machine turns on (or gets plugged in), does anything happen...any lights come on?
Is the machine able to print from the computer and recieve faxes while the scanner error is present?  If so, you probably need a scan unit.
Oct 29, 2007 | HP Officejet 7130 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
66 people viewed this question
Ben Johnson
