Question about Home
Stopping Hose Drip in Power Shower NT201-T
Help to fit Valve service pack on power shower NT201-T (New Team)
  • 3 Answers
What type of valve is it, is it a tmv2
Posted on Feb 17, 2009
My shower does not stop when turned off. It still runs fully for half an hour and then dribbles all the time
Tell us what type of shower. Power shower with a pump? Mains water power only? How old is it? Who fitted it? Does the control valve feel like its working properly?
Aug 12, 2015 | Home
No water flow from new american standard marquette showerhead
I think fitting of your shower is not proper. You have to fit it properly if you can or you can call a nearest Plumber to solve your problem.
Mar 13, 2014 | American Standard Home
The water coming out the shower jets is not powerful, help?
follow this steps and fix it. God bless you
If a faucet leaks, replace seals and gaskets .
If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
Moen Refresh? Shower Head 3-Way Combination Pack I just bought this and am having problems with the install. The hose to the handheld leaks on both ends no matter how tightly it's screwed in.
Hi Rebecca,
Sorry to hear that your shower head hose is leaking. If you could please provide a few details to our Consumer Services team, someone can help you reach a solution. You can either visit http://www.moen.com/consumer-support/contact-us or call 1-800-BUY-MOEN.
Thanks
-Olivia from Moen
Jan 06, 2011 | Moen Home
I have a drip, drip, drip from my shower head on my triton t90x can you please advise. thank you
A shower head will drip for a period of time but I will assume that it is dripping continually. Servicing the Mixing Valve is what is needed to fix the continual drip. there are several 'O' rings washers that eventually wear down causing problems. These parts are serviceable and kits with instructions can be purchased at plumbing shops, DIY Stores, Hardware Stores. I hope this has helped thanks for using FIXYA. Good luck and have a great day. Jeff
Apr 07, 2010 | Home
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Stopping a shower faucet from dripping
There are two things that can cause the shower valve to leak. One is calicum build up on the vlve parts and the other is the O-rings are worn out. Turn water off that feeds the shower and remove the handle on the shower valve then remove the cover that covers the valve body, next find a wrench that will fit the outside of the valve core and remove the core with stem of the valve. Go to any hardwate store and buy a new gasket kit or o ring kit. This is avaliblity at any hardware store.
Sep 19, 2009 | Elite Home
SHOWER HEAD DRIP
the problem is in the shower fitting the part with the handle ,depends on who made it but you replace washers or a cartridge some times easy some times not
Aug 11, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Been using shower for a couple of years .when fifished showering it will not shut water off all the way felt like stem was stuck not going back to close of water supply.After forcing it back all the way it...
First determind what side is dripping(hot/cold) then turn off water to entire house unless you have separate shutoff for shower behind wall. take a screw driver remove handle then use channel lock pliers to remove stem on the bottom side of the stem there will be a screw with a rubber washer on it you must remove the screw and replace the washer them re assemble Oh go to home depot and buy a the assorted pack of washer for faucets and stems find one that fits the pack cost about 4.99 best to change both rubber seal washer on hot and cold sinc e you have the water off
Jul 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
145 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
