Nuvi 660 thinks it is in Kansas
I have tried to reset the nuvi pushing the lower right hand corner, reseting locale, and reseting back button. it will not change. it keeps asking me if i am indoors and if i am in the state of kansas. i always press NO then it disconnets me. is my nuvi fixable? or damaged?
it went bonkers as i was on the highway driving. please help me! i can't afford to buy another gps.
  • ccatena300 Feb 04, 2009
    Thank you! I was trying to reach back to the individual who posted the instructions below and it worked. And thank you for telling me that Kansas is a default location.
    These are the instructions I got from Garmin as how to do the Master reset:
    Here are the steps to backing up the favorites on your unit and then performing the master reset. First, you’ll want to plug your unit into your computer via USB cable. Once it’s plugged in, you’ll want to go to My Computer in your start menu or from your desktop and double-click on the Nuvi. At this point, you should see a few folders, but you’ll want to double-click on the Garmin folder. Here, you’ll want to look for the “GPX” folder and you’ll double-click on that. In this folder, you’ll want to drag and drop the file titled “Current.gpx” to your desktop to copy it. Now you are able to do the master reset.
    To do that, you’ll want to start with the unit turned off and press and hold on the upper left hand corner of the touch screen. While holding the touch screen, power the unit on and continue to hold. You should get a message that asks if you really want to go into maintenance mode and you’ll want to select “Yes”. At this point, you’ll want to select “clear user data” and then select “Yes” when it asks you if you really want to clear user data. Now, the unit should restart and you’ll want to take it where it has a clear view of the sky and let it sit for up to 30 minutes to acquire satellites. If after 30 minutes it does not acquire satellites, you can go ahead and reply back to me.
    Either way, once we have your unit back working again, you can follow the first set of steps again to get to the GPX folder and drag the “Current.gpx” folder from your desktop to that folder on your unit. This will replace your favorites
    Problem Solver:
  • 12 Answers
Kansas is a default location. It is not getting a sat signal as it asks about being indoors. New GPS or one turned off for a long period of time or moved a large distance while off will need to download a new constellation table before it will be able to function. This may take 20 minutes or so. Unless it is a defective unit, place it where it has a clear view of unobstructed sky. And leave it on a while. Once it learns what sats to expect, it should begin to work.
Posted on Feb 01, 2009
Garmin 660 touchscreen inoperative
Try performing a soft reset.
Disconnect the unit from any external power supply.
Depress the reset button behind the flip up antenna.
Reconnect the unit to the power supply and let it should work normally.
If the soft reset does not work, try performing a hard reset.
Caution: Performing a hard reset will erase all user information including favorites and bookmarks and restore the unit back to factory settings. Be sure to save any information before performing the hard reset.
With the unit off, press and hold the lower right hand corner of the screen while turning the power on until a pop-up appears. Press "Yes" to restore the unit back to factory settings.
Sep 18, 2011 | Garmin Nuvi 660 GPS Receiver
I have a Garmin Nuvi 660. Serial # 12P414268. I turn on my GPS and I can't key in my PIN number. Nothing is working. I recently returned from a trip to Kansas. The unit worked great until we were...
Power off your Garmin 660 unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
To back up your Garmin.
  • From the garmin drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  • After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Garmin, but be sure to rename it 'temp.gpx'.
  • On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Garmin where they are actually stored
  • You can also try powering off the unit and hitting the reset button under the antenna, or try the information above but pressing firmly the lower right side of the screen.
    This should reset your Garmin then I would suggest updating your device at the Garmin site. I will attach a link.
    Thanks for using FixYa
    https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
    May 23, 2011 | Garmin Nuvi 660 GPS Receiver
    Hello i have a nuvi 660 and it does not receive any satelite it says aquiring satelites and never gets any
    To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1100, 1200, 1300, 1400 or 1600 series device:
    Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings. If you would like to back up your favorites you can find instructions to do so here.
    1. Start with the unit OFF and unplugged from power
    2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
    3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
    4. Release the power button when the device powers ON
      • You will see a new message: Do you really want to erase all user data?
    5. Remove your finger from the touchscreen when this message displays
    6. Touch Yes
    The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
    Oct 23, 2010 | Garmin Nuvi 660 GPS Receiver
    How do i restore my garmin nuvi 650 back to factory settings
    You can try a reset by performing the following, just keep in mind that any favorites and waypoints that you might have entered will be erased.
    Touch and hold the lower right hand corner of the screen then power the unit on.
    You will see a message: "Do you really want to erase all user data?"
    Remove your finger from the touch screen when this message displays.
    Touch Yes
    Please let me know if if helps
    Thanks
    Jun 13, 2010 | Garmin Nuvi 660 GPS Receiver
    Trying to reset my garmin nuvi 350 but per-boot mode is keeps coming up. i hold down the left corner and hold the power button i don't understand why i can't reset it. HELP im going nuts
    (G-Brand): Place your finger over the lower left-hand corner of the screen (upper left-hand corner for a 6xx series) and hold it there while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings and to a location of the manufacturer's headquarters in Kansas. This will also force your GPS to collect new satellite data. Your GPS should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
    - Jim
    SHARCNET-USA
    Dec 10, 2009 | Garmin Nuvi 350 Car GPS Receiver
    - Jim
    SHARCNET-USA
    Dec 10, 2009 | Garmin nuvi 200W GPS
    My Garmin nuvi 260 is only 6 months old and it can
    First make sure you have the latest software in it.
    If it does try a Master Reset.
    Lastly, unless you're in a strange location with poor reception. Take it back. Or, it's still under warranty.
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on your nuvi 260 series device:
    6. Touch Yes
    Aug 04, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
    Garmin stuck on foreign language
    Turn the unit off. push the lower right corner until the unit comes on. a page will appear with the arabic and it will show 2 radio buttons push the right hand one and it should reset.
    Jun 27, 2008 | Garmin nuvi 250 GPS Receiver
    79 people viewed this question
     Grubhead
    Grubhead
