Question about Wharfedale DVD-M3 DVD Player
Progresive scan problem and didn't get picture in tv
Wharfedale dvdrhd400 recorder
Our problem was that we could not get picture on the tv screen but it got sound.We tried to solve it using different techniques like the setup,video source,function keys pressed on remote control by trial(only assumed) and error as we could not see the screen and I used scart with every conection but three point pin was free so I put only one pin in video out put and at that moment I could see the picture on tv.
Posted on Jan 31, 2009
I have got sound but no picture
don´t you by mistake activate the progresive scan function
Jan 13, 2010 | Wharfedale DVD-M3 DVD Player
I have recorded a film and want to remove the adverts but i can't work out how to segment. It is the wharfedale DVDRHD400
Scan the DVDR with TMPGEnc v4.0 Xpress this way you can cut clip to you hearts content.
Jan 11, 2010 | Televison & Video
Wharfedale 80GB DVD HDD Recorder DVDRHD400 USER
remote not operating, unit working otherwise, h/d not full, dvd's play ok
Oct 26, 2009 | Televison & Video
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
My DVD player LG DR165 DVD Recorder is giving me an error.
PROGRESIVE SCAN will only work with an HD TV and it does not work via the scart lead. Select off for it if you have an old TV. If you can't get it to stop coming on by doing what it says to do, then you have an electrical fault on the LG.
PROGRESIVE SCAN itself is a method of getting high quality images on HD TV's via the special sockets at the back of the DVD.
Mar 30, 2009 | LG DR-4810 DVD Recorder
WHARFEDALE DVDRHD400
when you have split and seperated the part of the viceo you want to put onto a dvd, highlight it on the list of recordings and press the blue "playlist +" button on the remote. This will have added the recording onto the list of items to be recorded to dvd. Now press the red "RECORD/DUB" button. This will then record the file to the disc.
When y ou are notified that the process is complete,you will need to finalise the disc in order for it to be playable on other machines.
While the DVD is still in the drive uses the blue "function" button, and select DVD.
Shortly a list of titles on the DVD you have recorded will appear. Press the "UP" arrow on the remote once and a new menu will appear. One of the options here is to finalize disc. hilght this option and click the "RIGHT" arrow once - press "select" to finalise the disc.
Aug 30, 2008 | Wharfedale DVD-M3 DVD Player
Wharfedale DVDRHD400
where can i get a remote for the wharfdale dvdr hd400
Jan 15, 2008 | Wharfedale DVD-M3 DVD Player
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
This tv has inbuilt freeview, how do i use a dvd recorder to record off it?
The Wharfdale Machine that has Freeview has an F on the end ie vdrhd400f. It may be yours is an analogue version. Always possible that you can use the TV as an output via a scart to record what you are watchin
Jul 14, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Wharfedale DVD-M3 DVD Player Logo
276 people viewed this question
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jonathon summesfield
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
