Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Epson Stylus Photo RX600 Error Message
I turn on the printer and it reads printer error occurred on the screen. What does that mean and its says sheck Users Guide. I dont know how to fix it can you help me
    President:
  • 2,976 Answers
Unplug the power and USB cables. Reboot the computer. If that doesn't work, reinstall the software. Here is a link for the manual. It's big so it takes a couple minutes to load.
http://files.support.epson.com/pdf/rx600_/rx600_01u1.pdf
Posted on Jan 30, 2009
    Scholar:
  • 118 Answers
You need to check and see if it's not on pause and it's default. You need to go to "start", "control panel", then "printers and faxes" it will bring up the printers. First make sure it's the default with a black check on it. If that's not then right-click it and select "set as default". If that's okay then right-click again to make sure that it is off pause. right-click and select "resume" if it's not up then it's okay.
    Brigadier General:
  • 8,619 Answers
Hi!
Please tell me what error does it show? Is there any error number written? Try turning off the printer and connect it to a diffrent usb port and then turn it on.
    President:
  • 1,214 Answers
Do you have the users guide?
How long has it been since you used the printer?
Reply back and I will help you to resolve, but most often the problem is the ink cartridges are dry.
  • Epson Master
  • 19,396 Answers
It does mean that there is a problem, it may be caused by paper stuck inside, or cartridges not well placed, cartridge sensor dirty, or an internal fault.
  • Remove both cartridges.
  • Unplug printer powe cord and usb cable.
  • Wait ten minutes and plug back power.
  • After printer has cycled and is on plug back USB.
  • Start again procedure for replacing cartridges.
Check also that there is no paper inside, and that the cartridge contact inside the carriage is not dirty, in that case clean it with cotton and alcohol.
  • Ginko
    Ginko Jan 30, 2009
    Check also your manual, around page 63 is explained how to contact Epson when you get this error.
    Alternatively you need to use a service program, and this service utility but if you use the software in the wrong way you can damage the printer.
    Check also if ssc utility
    works on your model.
    On several epsons also the following reset works, hold down the buttons Power, Setup, and Stop for ten seconds, until printer powers off, then restart.
My epson stylus photo RX600 says Scanner error occured. What do I do to get printer working again?
Hello, all you have to do is to reinstall the printer software in the system, so it can repair any error that is occouring
Mar 27, 2011 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson RX600 service required. How can i reset the printer and get rid of the error message?
I just had this same error message pop up on my RX600 yesterday. There is a utility that you can d/l from the Epson website to reset the counter at the link below.
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
The reason the service message pops up is that it is telling you that the waste ink pads are near the end of their service life and probably saturated with ink. You should still clean the waste ink pads or ink will eventually run out the bottom of your printer and create a big mess. If you do a Google search for something like "rx600 waste ink pads" there are some how-to discussions on doing this yourself. I'm going to clean mine later today.
They say it's not hard to do and you don't have to disassemble your printer, just use a toothpick or modified paperclip to remove the pads after you park the cartridges in their "replace ink cartridge" position and unplug the printer. A more detailed procedure can be found with the Google search.
Aug 25, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600: Banging noise when turning on printer
Ok I think this is the cartridge carrier doing the banging I have had this on 2 or 3 epsons that I oncwe owned. If you clean those rails that the cartridge container slides on the banging should cease. Dont need to oil them just a damp cloth will do it. You can try sewing machine oil later. only a very small drop ( smidgen) on a cloth to wipe both rails.
Please rate our help and keep this site alive
Aug 16, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
EPSON STYLUS PHOTO RX685
try with chip reset for all you cartridge
Jun 29, 2009 | Epson Stylus Pro 10000 InkJet Printer
Error Message
Please check connecting cables with PC.
Unplug printer form AC outlet for couple of minutes and replug back in and check.
Jan 30, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson printer -parts at their end of life!
Where can I find ink pads for my Epson Stylus Photo Rx600 ?
August
Doodlehyde@juno.com
Jul 29, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Priner error occurred.Please see users guide?
Try turning off the printer and turning it back on. If the error persists, it's time to call Epson and have them service the unit.
Jun 20, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus RX600
it seems your printer is having a hardware problem.plz send it for servicing
Apr 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Cannot read memory card or storage device
Are you infact trying to do this or have ever done this?
Sep 08, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
443 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
