Question about Hotpoint TDC32 Electric Dryer
Connections on creda 31378, machine to AC CCT on display panel.
Some one has removed the wiring on the AC power Circuit located in the display panel. I don't know for sure which is which. There are 4 wires that attach to the board, and 2 that attach to an options switch ( due to location of wires that's easy to work out ). I've mocked up a CCT diagram andbelieve the connections are as follows (numbers on the board). '2' is live brown+white (relay switches power to 3), '1' is neutral blue (circuit from '2' through r1 r9 d1 to neutral), 3 is black since power needs to be switched in that direction, the last on fartherest away, is an led indicator which to be honest confuses me. I won't power up until I'm sure (POW!) Help please!
  • 2 more comments
  • grtn_gtr Jan 31, 2009
    I was given a solution that needed a part number. But the only detail I'm able to give is that it's a Creda 31378 (tcr2). I have a picture and circuit diagram of the unit (I'll send the 2 by email)
  • grtn_gtr Feb 01, 2009
    Thanks Ginko, I'll have to go back to the machine and get the part number (maybe from the display
    panel?) This is he unit.
    And this is the circuit diagram I've mocked up for it. Hope this helps...
    Sorry I've prematurely clicked the repost button. (It's put a "thanks for trying" note).
    The serial number on the opposite face of the door "S/N : 501240739. Thanks
  • grtn_gtr Feb 02, 2009
    I'm not sure MrMark52. I believe is was purchased here (UK).
  • 11,896 Answers
As far as I know with this model you should have one BLUE wire and a 'double' RED wire, that should go to the 'left hand thermostat'(THE ONE WITH THE RED DOT ON IT) And a single ORANGE and a single BROWN that should go to the 'right hand thermostat
The single orange and the single brown go to the right hand thermostat.
The double black/orange and the single blue go to the left hand thermal cut out (that has a painted red dot on it *)
The thermal cut out device is there to protect the element so by it blowing last time should mean the element is OK. It most likely went due to someone turning the dryer off without allowing it to complete the last 10 minutes of the cycle (cool down period)
Posted on Feb 01, 2009
    President:
  • 1,214 Answers
Was this machine built in the UK, Europe, or US?
We can help, but need more info.
stewartswitch@yahoo.com
  • Hotpoint Master
  • 19,396 Answers
Give me the exact model number or enter model number here to find schematics and wiring diagrams.
Posted on Jan 31, 2009
Outside overhead wires crossed and shorted while removing a small branch. It tripped the breaker. I reset breaker, then lost power to circuit without tripping breaker. Also lost power to a separate...
You need to trace out the circuit. Find out which receptacles,
and switches are not working. Starting at the panel, following
the branch circuit that doesn't work and check all the wiring connections. Make sure the power is off before you check these
connections for safety sake. NO SHORTCUTS!
Sep 01, 2013 | Electrical Supplies
Machine beeps continuously and display gives an E90 error code. What is wrong?
If this is a Zanussi washer then E90 indicates a communication error between the interface board (control panel) and the main circuit board. Unplug the machine from the power! and take the top off the machine, if you stand in front of the machine on the left side you should see the main circuit board along with a blue multi-wire cable going from it to the control panel (interface board). There is most likely a poor connection at one end or the other or maybe even both. This will generate an E90 error code. You need to remove the control panel by removing the screws located behind the soap drawer and also the plastic clips located along the top rail, disconnect the blue cable from each board one at a time and then plug back in making sure to firmly seat the connectors. These can become loose from miniscule vibrations from the machine operating. Put everything back together plug back in and it should work.
Mar 12, 2011 | Washing Machines
Kitchen circut was accidently turned off. Now whirlpool gold disher will not work(unit was not running and the door was not closed all the way when circuit was turned off, All circuit breakers are on)...
You can put the unit into diagnostics (press the following keys in order within 6 seconds HEATED DRY, NORMAL, HEATED DRY, NORMAL all the lights will come on and it will start a diag cycle) and see if it recovers. If not, you are looking at a electronic control, and yes you CAN change the part yourself.
Mar 08, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
THe control panel doesn't display.
TURN OFF THE POWER TO THE RANGE THEN LOCATE THE SCREWS AROUND THE DISPLAY PANEL REMOVE ALL SCREWS AND OPEN UP THE PANEL CHECK WIRES FOR ANY WARE OR TARE ALSO CHECK THE ELECTRICAL CONNECTIONS ARE GOOD .
Nov 20, 2009 | Amana ACF4265 Electric Kitchen Range
Where is the filter ?
Remove lower rear panel locate and remove large black hose at bottom right of washer, and clean filter ionside hose
Please rate my solution.
Thanks.
Jun 28, 2009 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Where is the battery located on the HP C6280 All-in-one printer?
Inside silly. ;)
(sorry couldn't resist)
Unplug,
Remove the right hand plastic side panel.
Ground yourself to discharge possible static electricity,
Remove the 5 screws holding the cct board.
Battery is on the cct board.
Be careful of damaging wires when reassembling.
Feb 16, 2009 | HP Photosmart C6280 Printer
Electric circuit diagram needed
I am afraid that you can not get a wiring diagram for these washers, the only chance you have got is to contact Hotpoint/creda and see if they have a service manual for sale.
Go to www.hotpoint.co.uk
Plz rate my solution.
Thanks
Jan 23, 2009 | Creda Washing Machines
Where is filter
Filter is located in the large black hose attached to bottom of drum, remove hose and clean filter.
Access is by removing lower rear panel of washer.
Plz leave feed back for this solution.Thabnks.
Dec 18, 2008 | Creda W100FW Front Load Washer
Holden vx commodore immobiliser
to fix the key you need a screw driver to pry the to halves of the key casing apart (make sure you have a spare set) taking care not to damage the internal electronic component board, because this electronic circuit board (cct bd) is powered by a 3 volt battery (which is also used to run the bios on computers) can be purchased for about 3 dollars from **** smiths, you need a small pair of side cutters to cut the metal tag connections between the battery and the cct bd taking care to note which is the positive and negative tracks on the cct bd, then using a soldering iron desolder the metal tag connections from the cct bd take care not to damage the copper tracks on the cct bd, try to use the proper desoldering technique (the copper gauze or a suction gun) to remove excess solder from the metal tags because they need to be removed, when the tags are removed from the cct bd there is a small hole on each copper track for the positive and negative reconnections to the newly purchased battery, use light audio speaker wire, black for negative and red for positive, presolder the wire ends first then cut the bear ends down and solder to the tracks taking care not to cross tracks with the solder, then shorten the both positive and negative lengths so the battery and the wires will fit back into the casing of the key and resolder the wire connections to the battery, before closing the key casing test the key to see if the immobiliser is operating then relocate the ring seal and close the two casing together with tape or reglue with arildite glue. if your soldering technique is not up to scratch practice your technique until you feel confident and this should save you about $100
Aug 02, 2008 | Graco Spree 511 Holden Travel System...
Hotpoint TDC32 Electric Dryer Logo
365 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
