Question about Krups Bravo Plus 872 Espresso Machine
Help! I think I broke my espresso machine
I left my empty (Krups) espresso machine on for maby an hour or so. It still works but has a horrible smell. What can I do to get rid of the smell and clean it? Did I ruin it forever?
    New Friend:
The machine has been left unused and uncleaned for too long. The **** has basically gone off giving you a smelly output. You need to clean the lines and system out by flushing out the dirt accumulated in the lines and the heater. I managed to fix mine by running it over a couple of days, pretending to make coffee with no coffee in it of course for about 50 times i guess! Run the steamer as well! I used diluted vinegar in the water tank, also used diluted lemon juice, even used diluted dishwasher blue finish to finally slowly get rid of the smell. Dilute your acids or you will cause damage to the rubber seals. After many more rinses running it with with just water the unit is as good as new. When you`re happy with the colour and taste of the hot water make a couple of coffees and chuck them away. The others should be fine, the more coffee you make from then on the better it will be. "Worked for me!"
Posted on Dec 08, 2012
    Problem Solver:
  • 15 Answers
Most likely you burned the rubber gasket.
UNPLUG your coffemaker!!!
If you remove the gasket and the little metal filter attached by a screw and clean it off well and put a new gasket in it should solve your problem.
Posted on Sep 26, 2009
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
Leaking Krups XP4030 Espresso Machine
i think it is better if you try contacting ur service centre
Jun 28, 2008 | Krups XP4030 Espresso Machine
Krups machine thinks the reservoir is empty and will not brew but the reservoir is full
check for a float lever inside the reservoir if there is one. It may be stuck. Just wiggle it and it may work again. I dunno if this is the answer but hope it helps!
Jul 19, 2014 | Krups Coffee Makers & Espresso Machines
Code 12 krups
There was no ejection switch pulse during 2x empty cycles. Inspect the switch or what activates the switch, check the wiring to the switch and PCB. Is the chamber clogged with grinds.
Jun 10, 2014 | Krups Small Appliances Espresso Machine
Its about my Krups 8220. It gets stuck after it tells me to empty the two containers, immediately after cleaning the two containers and the coffee drawer it says machine in auto test and after it finishes...
Take it in to your Krups service agent, something is going to need replacing and they are by no means a simple machine to work on. You will fix nothing from the outside, it will need to be pulled apart.
Aug 19, 2013 | Krups Small Appliances Espresso Machine
Krups XP5240 very loud pop sound while steaming
Take it back to the retailer, tell them about the noise and the water leak. It's under guarantee so you should not be looking for any self help solutions, it's faulty.
Mar 12, 2017 | Krups Coffee Makers & Espresso Machines
I need a user manual for my old Krups T18 Espresso Machine
I'm not sure what a T18 is, but maybe you could post a photo. Since you mention 'old', I think of the first few Krups machines that I had. The looked like the Espresso Bravo Plus model 872. You can find a manual for that machine on the Krups site, but I've created a shortcut for you here. The photo looks like: palibaacsi_1.jpg Hope this works for you!
Jul 18, 2011 | Krups Coffee Makers & Espresso Machines
Dear Sir/Madam, Unfortunately the jug of the filter Krups coffee machine has broken. I would like to know if you sell it separately , as I am interested in buying it Thanks for your help Jordi SB
I broke mine and ordered a replacement part at krupsonlinestore.com for 24.99, I'm not sure if you can get it cheaper elsewhere. They sell other replacement parts as well.
Oct 12, 2010 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Bravo Plus 872 Espresso Machine Logo
274 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
