Question about Kenmore 659 Electric Dryer
Kenmore heavy duty 80 series
My buzzer stays on when cycle finishes.
  • Anonymous Jan 09, 2008
    kenmore 80 series gas dryer - timer stays on
  • Anonymous Mar 17, 2014
    I need to replace the female disconnect but I have know idea what gauge I need
    President:
  • 331 Answers
The buzzer is wired through a switch on your dryer motor. The switch is NOT a normal switch... it's a centrifugal switch meaning that it is mounted on the motor shaft and rotates along with it. When it "spins up" centrifugal force flings it outward to make contact with the terminals on the outer edge of the inner motor housing (This tells the timer that the motor is functioning properly and it can now begin to heat the clothes. This is also the switch that keeps you from having to hold in the "Start" button 'til the clothes are dry) When the timer kills power to the motor, the buzzer sounds off because of this switch. As the motor slows, springs retract the switch from the contacts and shut off the buzzer. Make sense so far? Sounds like your centrifugal switch is getting stuck. Unplug the dryer and gain access to the motor. Then use Contact Cleaner in a spray can to spray and clean every inch (inside and out) of the motor. This should get you going again.
Posted on Jul 29, 2007
SOURCE:
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Rinse cycle do not disengaged
does it drain?did you check the lid switch?
May 17, 2009 | Kenmore Washing Machines
No spin cycle
Something simple. Plug off the wall mains. Find your pump, dismantle to locate block. Before that you could check out your filter to clean out.
Mar 12, 2009 | Kenmore Washing Machines
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Turn off buzzer
some models have a buzzer in control panel which can be unpluged wire sealed off ather built into time and can not be turned offf good luck
Mar 04, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Turn off buzzer
Assuming you mean the end of cycle alert. The only way to do this is to follow the wiring diagram and install a switch to cut it off.
Dec 20, 2007 | Kenmore 73952 Gas Dryer
Kenmore/works on one cycle only
that machine have somes burn contacts on the timer replace with a new one and that is...good luck
Aug 07, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore 659 Electric Dryer Logo
527 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
