Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Error Message Hi i own an epson stylus photo RX600 i just put in a new black cartridge. but that was never the problem there is a error message and it says print error occured please see the Users Guide. I dont know whats wrong can you help me?
    President:
  • 1,990 Answers
  • Epson Master
  • 19,396 Answers
  • Remove both cartridges.
  • Unplug printer powe cord and usb cable.
  • Wait ten minutes and plug back power.
  • After printer has cycled and is on plug back USB.
  • Start again procedure for replacing cartridges.
Check also that there is no paper inside, and that the cartridge contact inside the carriage is not dirty, in that case clean it with cotton and alcohol.
Posted on Jan 30, 2009
  • 10,594 Answers
Please check connecting cables with PC.
Unplug printer form AC outlet for couple of minutes and replug back in and check.
Epson stylus dx6000 error message e-02 have tried
Hi
Chances are the mechanism to recognize the ink cartridges is already damage and it may cause a lot having it replaced. I suggest to get a new printer instead specially if you have tried reseating the ink cartridges several times and won't work still.
Thanks for using Fixya
Oct 14, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Epson RX600 service required. How can i reset the printer and get rid of the error message?
I just had this same error message pop up on my RX600 yesterday. There is a utility that you can d/l from the Epson website to reset the counter at the link below.
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
The reason the service message pops up is that it is telling you that the waste ink pads are near the end of their service life and probably saturated with ink. You should still clean the waste ink pads or ink will eventually run out the bottom of your printer and create a big mess. If you do a Google search for something like "rx600 waste ink pads" there are some how-to discussions on doing this yourself. I'm going to clean mine later today.
They say it's not hard to do and you don't have to disassemble your printer, just use a toothpick or modified paperclip to remove the pads after you park the cartridges in their "replace ink cartridge" position and unplug the printer. A more detailed procedure can be found with the Google search.
Aug 25, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600: Banging noise when turning on printer
Ok I think this is the cartridge carrier doing the banging I have had this on 2 or 3 epsons that I oncwe owned. If you clean those rails that the cartridge container slides on the banging should cease. Dont need to oil them just a damp cloth will do it. You can try sewing machine oil later. only a very small drop ( smidgen) on a cloth to wipe both rails.
Please rate our help and keep this site alive
Aug 16, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600 Error Message
It does mean that there is a problem, it may be caused by paper stuck inside, or cartridges not well placed, cartridge sensor dirty, or an internal fault.
Jan 30, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus RX600
it seems your printer is having a hardware problem.plz send it for servicing
Apr 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
ERR 1C
Epson printers are known for this sort of thing. You left the printer too long without cartridges and the heads dried up. Buy a new printer and this time don't buy Epson.
Feb 21, 2007 | Epson Stylus Photo 915 InkJet Printer
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
