Question about Sennheiser 100/500 G2 Series Wireless Combo Kit EW150ENGG2C Microphone
Frequency clash i run sound for my school and we just recently got 8 Sennheiser ew 100 g2 wireless microphones. they are brand new and all have the same frequency. Now....i know how to set it but since we have 8 i decided just randomly coming up with numbers is a bad idea(we have a feedback issue as it is) so i was hoping someone out there might have an idea of how i should assign frequencies (also note that there will be a total of 12 microphones running at once for the show) to minimize feedback and signal crossing.
    Problem Solver:
  • 6 Answers
Download Sennheiser intermodulation software called SIFM
http://www.sennheiser.com/sennheiser/home_en.nsf/root/professional_wireless-microphone-systems_sifm-software...after learning where your open TV stations are, (with the freq finder http://www.sennheiserusa.com/findfrequency/default.asp)
you can insert numbers at least 200 khz apart (never the same distance though!) in to SIFM for intermod calculation)
I dont know about your feedback problem but this is how you set yourself up for clean transmition. here is some info on intermod..
http://www.sennheiser.com/nordic/icm_no.nsf/resources/User_Manual_pro_US.pdf/$File/User_Manual_pro_US.pdf
Posted on Jul 15, 2009
There are different frequencies available and being used in each location.
To get a basic idea of which frequencies are available in your area, try this online tool:
or use the literature provided with the Sennheiser gear (usually a useful chart comes with the wireless gear).
Also, remember that your transmitting frequencies need to be spaced apart a minimum of .400 MHz (or 400 kHz).
Frequency selection shouldn't cause feedback problems though. If you select a frequency for a mic that a local TV station is already using to broadcast, it will cause RF Interference (Radio Frequency). You'll probably hear static noises, pops, or since your Sennheiser has a Squelch feature, just drop-outs in audio.
So first consult the available charts to find a set of frequencies that should be available in your area. Then, if one of your mics is experiencing such an issue, try moving it .400 MHz to the nearest unused frequency and see if the RFI goes away. Repeat until the RFI no longer manifests.
Posted on Jul 06, 2009
Issue more complicated than originally thought!
This isn't a solution. But after I've gotten into my microphone with the same issue using a torx screwdriver I found that I (Electrical Engineer) don't have the proper equipment to fix the issue. Roughly 100 dollars (Flat rate) and a send off to Sennheiser is your best bet.
May 22, 2012 | Sennheiser 100/500 G2 Series Wireless...
It appears the power on/off button has been pushed in or broken off on a wireless EW 100 G2 microphone. ID # 90913 Serial# 111619
Often the rubber button is pushed into the microphone.
You can easily disasemble the unit.
Just open the batterycase, you will find some small torx screws.
Regards,
Gerard
Mar 22, 2011 | Sennheiser Audio Players & Recorders
What would it cost to repair the on/off switch on ew 100G2 sennheiser ?
To repair the on/off switch of the handhelt it would cost abt 15 minutes and $2,00 for the switch.
So that would be $20-25.
Reagrds Gerard
Oct 03, 2010 | Sennheiser 100/500 G2 Series Wireless...
WHAT PLACE repair ew 100 micro, d ON/OFF switch
You're local Sennheiser dealer can fix it, no problem.
The repair takes a half an hour.
Regards,
Gerard
Mar 04, 2010 | Sennheiser Audio Players & Recorders
I have 3 sennheiser ew100 G2 handheld mics which don't work properly ( rattling sound ect;)i would like to send them off to you to get a quote on how much to repair them how do i go about this.
You can send them to Pro Line Music
490 Lincoln Highway
Fairless Hills PA. 19030
215-736-8055
It will cost $65. for evaluation + parts+ aditional time past 1hr. + return shipping.
Jan 13, 2010 | Sennheiser Evolution G2 100 Series UHF...
Sennheiser ew 100 g2 handheld microphone loose coil in capsule?
I had a similar problem with a sure sm 57 that I used on a guitar amp. I don't know if this is the correct fix but it worked for me. I took thin strips of paper to use as spacers and placed them evenly around the coil. I used a hot melt glue gun and placed 3 small drops around the edge of the coil. Remove the spacers and the coil should be secure.
Joey Clay
Oct 24, 2009 | Sennheiser Evolution G2 100 Series UHF...
455 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
