Question about Sony Ericsson W850i Cellular Phone
Startup problem i selected to perform the "master reset" setting. afterwards the phone says displays "please wait".... it has been like that for 6 hours now... Please help
It is okay sony ericssons can take up to 24 hours to master reset it took me 12hr to reset my w580i
Posted on Feb 05, 2009
Phone reset
Here is how you perform a Master Reset on the Motorola VE-538:
1. Open your phone up and go to "Settings"
2. Next go to the selection for "Initial Setup"
3. Next go to the selection for "Master Clear"
4. Then select to confirm the option.
5. Now enter the security code which should be "000000"
6. Finally press select or ok and the phone will reset itself to the factory condition
Jan 09, 2014 | Motorola Mobility VE538 Cell Phone
Master reset keys in Sony Ericsson W995
performing a master reset
Ensure all content on your handset is backed up before performing a master reset, then:
  • Press Menu.
  • Select Settings.
  • Select General.
  • Scroll to and select Master reset.
  • Select either Reset settings or Reset all.
  • Select Continue/Reset.
  • The phone will now reset and restart.
Jan 20, 2012 | Cell Phones
How can i reformat my motorola cingular v3xx?
The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
Congratulation you have performed a "hard reset", "hard reboot", or "master reset" on your Motorola V3 RAZR and it should return to normal operating mode!
May 01, 2011 | Cell Phones
I cant format my cell phone its a motorola razor
6. Finally press select or ok and the phone will reset itself to the factory condition.
If the solution helps, please rate. Thank you.
Jan 13, 2011 | Motorola Mobility RAZR V3
How can i perform a master reset on a Samsung B3410
To perform a master reset, you will need the security code to be able to perform this operation.
First you go to your phones menu, then you select security, then you select reset, you will see 2 options, 1. Reset settings 2. Master reset. Select master reset, it sometimes prompts you to enter the phones security code or does not ask you for any code at all depending on the initial settings, Then you select yes when it shows the information that all saved files on phone will be erased. That way your phone will reset.
That is how you master reset your phone.
Take care and good luck
Dec 29, 2010 | Samsung B3410 Cell Phone
My android 3g T-mobile phone has a blue light on top and won't turn on even when hooked up to desktop with USB. help!!
you need to do a hard button reset and this will fix your issue 100%!!! i found the info at tmobile.com/forums.
myTouch: How to Hard Button Reset Options
01-11-2010 10:59 AM
If the handset is locked, frozen, or unresponsive, you can perform a master reset it using the hardware keys instead of the menu. A master reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). To perform a master reset using hardware keys, follow these steps:
1. If the device is responding at all, back up your data before proceeding.
Note: The device must be turned on to synchronize or transfer files.
2. Turn off the device.
Note: If the device is unresponsive and does not turn off, remove and then reinsert the battery.
3. Press and hold the Home key and the Power key for at least 25 seconds, even if the Startup screen appears.
4. Release the keys when you see a black screen with a warning sign.
5. Press the Home key and the Power key again.
6. When the Android system recovery utility appears, use the trackball to scroll to and select Wipe data/factory reset.
7. Once the device finished the data wipe, select reboot system now.
Dec 24, 2010 | Cell Phones
I am trying to unlock a AT&T Quick Fire phone can you help me?
Hi i'm Rain First lets try a Soft Reset.
Remove battery ,wait 1 minute replace battery and boot Mobile device.
If this does not work you will need to do 1 of 2 things. Take the phone in and have them reset it.
The other option is a Hard Reset.
To perform a Hard Reset :
  • Select Menu
  • Select Settings
  • Then select Security
  • Click Master Reset
  • Then select yes
  • Type Default password 0000 4zeros
  • Select done
Phone will reboot after it has performed the Master Reset.
I hope this information has been helpful.
Nov 25, 2009 | AT&T Quickfire Cell Phone
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
5. Now enter the security code which should be “000000”
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
I have a motorolla ming... i dont know the code for the master reset / master clear / its asking for a 6 digit code / i do see only in the manual a 4 digit code
You have the option of using Master Reset or Master Clear to reset settings, and remove information.
Master Reset resets all settings on device to factory default.
Master Clear resets all settings to factory default, plus clears all data from the device including: PIM data, Call History, Settings, etc.
To perform a Master Reset or Master Clear:
  1. Press Start.
  2. Scroll to and select System Tools.
  3. Scroll to and select either Master Reset or Master Clear.
  4. Press Yes when Alert appears.
  5. Enter Master Code (normally 000000).
Feb 19, 2009 | Motorola Mobility RAZR V3
Sony Ericsson W850i Cellular Phone Logo
126 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
