Question about Car Audio & Video
Power thanks for the quick help---- The power light is out--the hyponics light is out on top but the small blue lights are on
  • 11,896 Answers
BATTERY CABLE TO AMP B+
GROUND CABLE TO AMP GROUND
REMOTE WIRE CABLE FROM AMP CONNECTS TO BLUE REMOTE WIRE ON BACK OF CD DECK.
RCA JACKS GO FROM REAR OUTPUT OF CD DECK TO LOW FREQUENCY ON AMP INPUT.
Check Power cable fuse, check ground is grounded to non painted surface.
This is all you need to get it to work. If you still have a problem, then it is a bad capacitor inside the amp
Posted on Jan 30, 2009
Toshiba 56hm66, lamp replaced but lights still blink
Check the circuit boards to see if any have failed. They are small cylindrical objects. If the tops of any of these are bulged instead of flat then they are bad and board will have to be replaced. Hope this helps.
Jan 03, 2014 | Televison & Video
No info. No spin
i thing so call you phones service people they will help you
Nov 13, 2012 | Olympia InfoGlobe Caller ID
WHAT IS THE SMALL BLUE LIGHT FOR ON TOP RIGHT HAND ON A MITSUBISH
The blue light is usually for the high beam headlight indicator. If you feel this is not accurate, please describe its shape and I'll see if I can decipher it.
Mar 29, 2010 | 1998 Mitsubishi Galant
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
My hyponics 1500 watt amp wont work
if u say nothing is burned on the amp then check for a faulty speaker connected to it
Jan 20, 2009 | Car Audio & Video
When I push the power button, the blue light comes on but tv doesn't
It is the capacitor. It is really easy to fix, and it will cost you about $4. The capacitor is on the power board and it looks like a small battery. The bad capacitor will have a small bulge on the top, the good ones will be flat on top. You can buy them at Radio Shack. Just look on the side of the capacitor to see which one you will need. If you need any further info I would by glad to help. I have a 40in polaroid that this happened to and it works like a dream now.
Oct 26, 2008 | Polaroid FLM-2011 Television
Plantronics voyager 500a
With these units, if the earpiece battery is allowed to run down, it will switch off. When the earpiece turns off the base station starts to search for it, which is indicated by the flashing red power light. Also the blue light on the top of the base will turn off. The first step, which you have already done, is to charge the earpiece. Next, hold down the little black button that is on top of the earpiece for about 5 seconds. You should get a slow flashing blue light on the mic boom. Wait for about 10-20 seconds and the base should automatically find the earpiece. The red power light on the base will be steady and the blue light on top of the base will come on.
Sep 12, 2008 | Plantronics Voyager 500A Deskphone Adapter...
Programming an automobile keyless security remote
Have the same remote, just bought a 2000 astro cargo van with one of these, but no clue on how it works,, Would appreciate any info like model number of unit it self so I can possibly down load the owners/user manual.
Thank.
Nov 16, 2007 | Car Audio & Video
Blue Convergence Problem
see if the leads from the green crt Pcb on the green crt is long enough to reach the blue crt. If you hook up the working green circuit to the blue tube and it still dosent light up On the screen, then you know the tube is bad. Just a quick way to test crt's,. If it does light up then you have to trouble shoot the matrix for the blue tube. The drive maynot be vorrct the g2 voltage maybe not enough so then the screen block could be bad. I just wanna warn you against the very very high voltage inside these sets even when there not plugged in. BE CAREFULL PLEASE
Jun 13, 2006 | Philips 60P8341 60" Rear Projection...
Car Audio & Video Logo
125 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
