Question about Hotpoint HSS25GFP Side by Side Refrigerator
WATERLESS SIDE BY SIDE FRIDGE
I have a 99 kitchenaid(model KSRS2FGBL01) side by side that no longer gives me water.My red light was on for a while, then went green(no one will admit to resetting light, so not sure how it went back to green).So I replaced filter, turned water back on,nothing happened. I was sure that at 1 time,when using the water, it would have a click sound as if the unit was activated to disperse water. Now I hear nothing.Water isnt even going to ice maker. Is there another reset switch im missing, pump fuse blown, or .....? Im baffled.Hopefully you can help me. Thank you for your time
  • louis jenkins Jul 30, 2007
    Later I found that the ice maker is working, but still no water for drinking.I push the handle and hear nothing electrical .Under the door, I see where the water hose connects,I unplug it and hit the handle again(ive heard that sometimes the water can freeze in the door ),still nothing.Anymore great ideas would be again very helpful. Almost there.Thanks again.
    President:
  • 331 Answers
Your fridge utilizes a "dual coil" electro-mechanical water valve inlet system (the water from the wall is hooked up to it). One coil for the Ice Maker, the other for the chilled water. The chances of both valves failing at the same time are slim to none... and slim just left town. First, verify your filter installation. Remove it completely, 1/4 turn left and pull. Then reinsert it fully and lock it in solidly with a 1/4 turn right. Pull on it hard to make sure it's locked. Second, get a pair of slip joint pliers or a 7/16" open end wrench. Pull the fridge out from the wall and turn the water off. Remove the hose going into the fridge. Hold the hose in a bucket or pan and slowly turn the water on and let it run for a second to verify water. Then reinstall the hose back on the valve assy. Now, try your water dispenser. If this doesn't work, we can go deeper. Post back with your findings, please.
Posted on Jul 29, 2007
  • Tracy Farrell
    Tracy Farrell Jul 30, 2007
    OK, I've seen this before. You changing the filter didn't cause the problem, it is purely coincidental that the problem occurred when it did. The Water side of your valve, I believe, has failed.
    In order to safely test this, you'll need to purchase a tool. It's a "Volt Stick", no Home Owner should be without one, really. A great little tool to have around to quickly test "dead" power outlets and such. See one here...http://cgi.ebay.com/Greenlee-GT-11-Teste... With this tool in hand, you are armed to locate the problem. (Home depot carries these) Pull the fridge out and remove the cardboard cover back there. Now remove the 2 screws holding the valve in place and pull the valve out of the unit. You'll see two solenoids there w/2 wires going to each, you'll be testing the one that's connected to the larger (5/16") plastic tube. Remove the wire harness that's attached to this solenoid and place your new volt stick right between the wires. Now try to get some water out of the dispenser and look at your new Volt Stick, is it glowing? If it is, you have 120V to your valve, but the valve isn't opening. You'll need a new valve. Part number= 4389177, sells for about $55.00 at your local appliance parts store.
Kitchenaid side by side fridge is freezing food
you have a bad damper assy.when it gets cold enough in the fridge section the damper door closes so the cold air can't blow in from the freezer side,the door isn't closing allowing the cold air to keep coming into the fridge side 2220377 part number and this is electronic damper.if you order it from repair clinic you have 365 days to return it if it's damaged or it isn't your problem they will take it back,i'm 99 percent positive that this is your problem,when i would call the customer and get model number and ask a few questions i would take this with me when i go to the house from the discription you're giving.
Dec 05, 2013 | KitchenAid Superba Architect KSCS25INSS...
I cant believe i cant find the model # of this fridge but anyway , i installed a new water filter a purr #4396841 and did it according to the instructions , did everything but the red light remains, wonder...
The model # is located inside refridgerator door on the upper right side panel.To reset the light you have to open fridge door and by the light there is a button you have to push in the button 5 times in 10 seconds to reset.Hope this helps if so give us a 4 thumbs up. THANKS
Mar 03, 2011 | Whirlpool GD2SHGX Refrigerator
Where can i get a filter for this fridge??
You are looking for filter part # 4396711. If you type that number into google it will give you many options. Also you could try any store selling KitchenAide appliances. Hope this helps
Oct 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Fridge Filter
the filter islocated behind the toe grille, ordering instructions areprinted on the filter itself, and resetting the light is a matter of holdingin the button for 3-5 secs, its filtering your water and ice
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Blinking red light on kitchenaid side by side no ice, but still have cold water
I had a blinking light, two flashes then pause, I did two things, not sure which worked, blow dryer to the black tube, and took a Q-tip to the sensor eyes (on both side of the walls), after a few minutes of trial and error, the light went out and I heard the water from the fridge, so hoping this would solve the ice maker issue!
Mar 30, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
107 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
