Question about Jensen CD310X CD Player
Need user manual to find out what buttons are for and how to make display light briter cannot see in daytime
    Scholar:
  • 116 Answers
Here you go
http://ww.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man&e=1#myManualsDownloadForm
Posted on Jan 30, 2009
I have a 2005 GMC Yukon Slt.how do I turn daytime driving lights on.?I was messing with buttons,trying to familiarize myself,& accidentally turned lights off
Owners manual will give info on this. If no manual, scroll through steering wheel functions until info is displayed on dash ans select as necessary
Nov 07, 2015 | GMC Cars & Trucks
Screen has darkend and wont get briter
Are you running on batteries? Has you laptop go into hibernation? You can adjust display dimming in power stttings, by right clicking the Batery icon in the taskbar notification area and opening the power settings. if that's whay you mean? I need more information to give a informed solution. If you plug in the laptop to AC does it change? Try re boot.
Nov 05, 2012 | Samsung Q310-34P Mobile Notebook
How to make screen briter
Try FN and the F-- row of keys. There is usually one that will make it get brighter. Just try not to hit the ones that will put it to sleep or shut off the screen. Those should be indicated with little symbols.
If that doesn't work you can go to control panel and select Displays and under that it should give you an option to adjust brightness!
Sep 07, 2012 | Dell Latitude D620 Notebook PC
How do day time running lights works I have no running lights is there a bulb I can change
In the case of daytime running lights, they will normally be your yellow lights or low beam lights on the front of your car and usually will not include rear lights. Older cars usually will have to have them turned on manually (refer to users manual) or will not be included at all. In a case as such, you can choose to have our driving lights on for safety purposes especially on overcast days.
Mar 21, 2011 | 1995 Honda Accord
Daytime running lights and blinkers do not work
the lights are controlled by a module, it is the DRL module, replace it. also try this
On the inside of the car next to the light switch there is your dome light button. GM made it to where you could turn off the daytime running lights by pushing it three times in and out. Turn the vehicle on then do this. Your daytime running lights should work after this.
May 14, 2009 | 2005 GMC Yukon Xl Denali
Reset initial settings
You can return to the default settings by pressing and holding the Light
button. RESTORE DEFAULT? is displayed. Press the / buttons to select YES or NO. Press OK.
In the User Settings menu, you can edit your personal data, weight, height, birthday, gender, and extra user settings.
1. Start from the Time of Day display. Press OK. Exercise is displayed.
2. Press the / buttons until Settings is displayed. Press OK.
3. Press the / buttons to select USER. Press OK.
4. Weight: Adjust the weight with the / buttons. Press OK.
5. Height: Adjust the height with the / buttons. Press OK.
6. Birthday: Adjust the month (mm) or day (dd) with the / buttons. Press OK.
Note: You can skip the date of birth date setting and accept it as it is by pressing and holding OK.
7. Adjust the day (dd) or month (mm) with the / buttons. Press OK.
8. Adjust the year (yy) with the / buttons. Press OK.
9. ***: Select MALE or FEMALE with the / buttons. Press OK.
the manual for your watch can be downloaded here if you want to change other settings
http://www.polarusa.com/us-en/support/product_support?product=276&category=Downloads&documenttitle=%0AUser+Manual+for+F6+in+English&document=/gip/PEUS1kb-public.nsf/web_cat/85256F470048B0BC852574730060F31E?openDocument
Mar 19, 2009 | Polar Exercise & Fitness
Had power outage and now the Neptune Washer won't even light up. Washer was not in use at the time. Checked the breaker and outlet and all live and functioning. Is there a reset button that will reset the...
no! did the porew surge when it came back on,like the lites in the house went briter than normal/may have damaged main control board in top console.you will also fine a tech sheet up there.see if you can get some glues their.God bless.tom
Dec 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Daytime running lights not working
On the inside of the car next to the light switch there is your dome button. GM made it to where you could turn off the daytime running lights by pushing it three times in and out. Turn the vehicle on then do this. Your daytime running lights should work after this.
DeViouS Tuning
Dec 14, 2008 | 2005 GMC Yukon Xl Denali
Cannot reset maintenance light on 2003 Honda Element
The dealer has issued a technical service bulletin regarding the maintinace required lamp I belive it states all lights headlamps tail and side markers have to be off and the door must be closed in order for the reset to work. How to Reset
Press and hold the trip/reset button, turn the ignition switch ON , and continue to hold the button for more than 10 seconds. this should fix the problem if not the the daytime running lights will have to be disabled before it will reset.
Sep 16, 2008 | 2003 Honda Element
Jensen CD310X CD Player Logo
541 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
