Question about Xerox Phaser 8200 Laser Printer
Phaser 8200 Bulb Replacement Instructions
Hi I saw that you had replacement instructions for the halogen bulbs in the Phaser 8200. Would you be able to email them to krum04@gmail.com? Thank you for any information! It would be a great deal of help!
  • 3 more comments
  • luteskl Feb 12, 2009
    Could you send me the instructions as well please
    could you email me the instructions as well i really need this fixed
  • mail663 Feb 21, 2009
    Could you please send me the instructions for the bulb replacement? Much appreciated.
    Paul
  • suphojlu Feb 24, 2009
    I encountered the same problem. My Phaser 8200 doesn't complete its warm up cycle and displays this error code on the display window 15.004.45.172027. Could any one send me the Bulb Replacement Instruction please? My email address is suphojlu@yahoo.com
  • Anonymous May 10, 2009
    I have the same problem as you guys. Could you please send me the instructions for the bulb replacement? My email address is ndhung08@yahoo.com
    President:
  • 2,072 Answers
I will send them to you.
Posted on Feb 01, 2009
How to replace driverside headlight replacement
I don't know how to replace the headlight replacement, but I can tell you how to replace the bulbs if that is what you want to know. It all depends on if your vehicle is equipped with halogen or xenon bulbs. I am posting instructions for both.
1. Turn the headlamp bulb plastic cap counterclockwise to unlock and remove it
2. Turn the bulb socket counterclockwise to unlock and remove it (xenon)
3. Disconnect the electrical connectors from the bulb terminals (halogen)
4. Unlock the retaining springs and remove the bulb
5. Release the ignitor and remove from the plastic cap (xenon)
6. Turn the high beam lamp socket counterclockwise to unlock and remove it.
Installation is the reverse order of removal.
Mar 06, 2012 | 2006 Nissan Altima
Phaser 8200 error code
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 Error 15,004.45:102501
Yes, that is a common problem, and not real hard to fix, but takes probably an hour to an hour and a half to repair. For someone that has never done it before that is.
First what the code means. That is a failure of the drum to heat up. The drum heaters are simply 2,, 150 watt Halogen lamps, mounted in a reflective heater. One or both of those bulbs has burned out.
The way you can tell is, turn the lights off in the room or office the machine is located. Then. looking on the right side cover, there are fan vents, opening up into the machine. Turn the machine on, and wait a minute or two, then look in that fan slot and see if you see a glowing in the machine. You won't. But that is how you know those lamps are not coming on.
You will want to replace both bulbs since you are taking that assembly out. I strongly suggest the Sylvania Halogens that are rated for 130 volts and are vibration protected. You can get them at Lowes or Home Depot, anywhere that sells Halogen lamps. You dont have to get the Sylvania ones, but they sure are the best if you can get them. The cost to fix it yourself is less than $20.
If you want, E-mail me at rak458@aol.com and I will send you the instructions on the repair. I dont have the manual. I will type it out step by step. Makes it easier I think.
May 19, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 error code 15,004.45:119696
If you take your time, Its not really hard, Just time consuming. I can send you written instructions.
May 17, 2009 | Xerox Phaser 8200 Laser Printer
Error Code: 15.004.45:113654
That code means the drum heaters are not working.
The good news is, yes you can fix it yourself.
The drum heaters are 2, 150 watt halogen lamps. One or both of them have blown out. If you want drop me an E-mail at rak458@aol.com
I will send you instructions how to replace them.
It would take 1 to 1 1/2 hours if you have never done it before. Lowes, Home Depot or any place that sells halogen lamps would have them.
I however, do highly recommend, if you can find them. Sylvania halogen lamps rated for 130 volts and have vibration protection. They cost slightly more, but well worth it. Besides even if you get those, you have less than $15 in the repair.
Let me know, I will send you the info. That's all your problem is.
May 06, 2009 | Xerox Phaser 8200 Laser Printer
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Error code 15.004.45.172027 on Phaser 8200
I would suggest calling a service agent and have him bring a paper pre heater.
Feb 25, 2009 | Xerox Phaser 8200 Laser Printer
2003 Mercury Sable headlight bulb replacement
This problem is now resolved, thanks to a prior post by sableowner.
http://www.fixya.com/cars/t1479995-2001_merc_sable_headlight_replacement
The 2003 Sable has the same headlight assembly and removal/replacement instructions as the 2001 Sable. Once I had this information in hand, bulb replacement was easy.
Jan 10, 2009 | 2003 Mercury Sable
Where in Belgium Europe can I find Heating halogen ligths for a 8200 phaser printer.On the old continent we use 220 volts. Xerox asks 200? plus a heavy repair fee ... Thanks for help
If you are able to do the repair yourself, then remove a lamp from the preheater assembly and look at the voltage and wattage on the bulb itself...on some there is also a lamp part number.
you can also order a repair kit from e-bay. The same lamps are used in the Phasers 840, 850, 860 & 8200
Here are 2 links that have what you need (if the internal voltages for the printer are the same in europe as in usa):
http://cgi.ebay.com/Xerox-Phaser-840-850-860-8200-Drum-Heater-Repair-Kit_W0QQitemZ230320054253QQcmdZViewItem?hash=item230320054253
http://cgi.ebay.com/XEROX-PHASER-860-PREHEATER-ASSEMBLY-650-4228-00_W0QQitemZ350139954330QQcmdZViewItemQQptZCOMP_Printers?_trksid=p3286.m20.l1116
Dec 14, 2008 | Xerox Phaser 8200 Laser Printer
Error phaser 8200
This error message is related to the drum heater malfunctioning. It is basically 4 small halogen bulbs that warm up the image drum. Sometimes one or two of the bulbs will blow causing this error. The part # is 650-4228-00 Drum/Paper Heater assy. It is not extremely difficult to change, however you need torx bit screwdrivers to remove the components, also there is a very delicate paper sensor that needs to be removed, so you may want to have a technician replace it.
Hope this helps!
May 20, 2008 | Xerox 8200/DP Thermal Printer
Xerox Phaser 8200 Laser Printer Logo
263 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
