Question about Haier HDN655E Dehumidifier
Dehumidifier efficiency The compressor is running but there is very little drying. Can you tell me what temperature I should expect the coils to run at. They are not very cold so I suspect the machine has lost gas.
  • martin_valen Feb 02, 2009
    We do have central heating!
    But yes I agree it will not work as well in the cold.
    My coil is not reaching anything like 40 degrees so I am happy that there is a lack of gas.
    President:
  • 1,214 Answers
I'm surprised that you are trying to dehumidify if you are in the northern hemisphere right now.
But, before you go off trying to fix the refrigerant, see if you can get a glass of ice water to sweat near the dehumidifier. While relative humidity might be high in cold climates right now, it's a relative number, as the total grains of moisture is far lower than what it would be in a warmer climate. Cold air saturates easier, because it holds less, moisture.
Most people use a humidifier in the winter because they want to saturate the air with water, which is better for the human body, and minimizes static electricity.
I can help you diagnose the dehumidifier if you want. The coil should only get to 40 degrees or so. But the sweating glass of water will tell you if there is enough moisture in the air for the dehumidifier to wring out.
Posted on Jan 30, 2009
  • Mark Egan Feb 02, 2009
    I am not certain the coil is supposed to reach 40 degrees. Let me look into it. It could be as high as 55-60 degrees.
    Did you try the glass of water sweating thing?
    One other way to determine if you need to dehumidify is to take a thermometer and put a wet cotton swab on the sensing end, then place in front of a fan for a few minutes. Read the temperature before the air moving past the cotton swab dries it out. This gives you the wet bulb temperature. Then, take the cotton swab off, and measure the temperature of the air again. This is the dry bulb temperature.
    Using a psychrometric chart or table, you can now read the relative humidity of the air.
    By the way, all the temperatures I have been giving are in degrees F, not C.
    Let me know what you come up with. If the unit is not very old, I would not suspect that is low on charge yet. And if it is, then it's probably new enough that it is still covered under warranty.
How do you clean the filter
In order to look up the filter change procedure I would need the specific model number. However, filter changes or washing should be done regularly. Look for a very simple lift-out design that is washable in the kitchen or laundry sink. Soak in soapy water and rinse with spray nozzle.
As for the symptom "Blows out warm air" this is expected. The dehumidifier is less than 100% efficient, meaning that the energy that is used produces heat in the exhaust air. A 100% efficient design would still send all the heat energy of condensation (endothermic phase change) into the exhaust air. You should expect 1072 BTU per pint (1 pound of water). This is far more than the heat of crystallization (144 BTU per pound of ice) and therefore much more sensible when you feel the discharge air from the dehumidifier. Dehumidifiers typically operate in basements to both warm and dry the area where a sump pump may be operating to remove the water that seeps through the foundation. A dehumidifier is not a good idea for warm areas of the house. This will decrease the efficiency by increasing the temperature differential needed to get the evaporator coil below the dew point to cause condensation. The condenser coil will be much hotter than expected if the unit is operated in a warm humid room. Only air conditioners which discharge condensate and exhaust air to the outside of the structure should be used to cool a room.
Jul 06, 2014 | GE 50-Pint Dehumidifier
The motor is still running fine, but the dehumidifier is no longer extracting water from the air and the water container is not filling.
John, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 19, 2011 | Haier 45-Pint Dehumidifier
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Need a repair shop in the baltimore area to look at my dehumidifier runs but wont pull water
It's cold outside. If the temperature is too low, the cold coils will just frost up and you won't get much water 'pulled'.
Check to see if the cold coils actually are getting cold when the unit is running and the control is set to cause the compressor to work-not just the fan.
If the coils are cold and full of frost or ice, the room is too cold for the dehumidifier to work. You'll have to raise the temperature of the room or wait for warmer weather.
If the coils never get cold, the compressor might be bad or the unit might have lost its freon.
I wonder, though, if it's just too cool and dry right now for a dehumidifier to be pulling more moisture out of the air.
Hope this helps!
Jan 01, 2011 | Haier Dehumidifiers
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Dehumidifier ices up
unplug and take unit apart,blow out dust then carefully spray some cleaner-degreaser on and wash both condenser and evaporator coils,then let dry throughly, try not to soak the electrics too much a little will dry, let dry throughly then start it and leave it run a few minutes carefully touch top of compressor head,if quite warm and one line isn't hot and the other line isn't cold entering and exiting the compressor and evap coil starts to ice again you may be low on freon(refrigerant)
Aug 29, 2009 | DeLonghi DE500 Dehumidifier
The dihumidifidier is not drawing water. It is
In order for the Dehumidifier to remove moisture, the coil temperature has to be below the dewpoint temperature. If you check with the weather station and find out what the dewpoint is in your area, then measure the coil temperature or cold line coming out of the coil,it has to be below the dewpoint to get moisture, you can also look at the coil and see if it's wet which will also tell you if the coil is below the dewpoint.
Aug 05, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Frostguard 36 Dehumidifier runs, but collects no water.
unfortunately it sounds as though your refrigerant leaked out. If your compressor is running and no moisture, this is probably the case. What is the temperature of the air coming out?
Jun 20, 2009 | Woods Dehumidifiers
Not working
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
Aug 27, 2008 | Dehumidifiers
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
Haier HDN655E Dehumidifier Logo
325 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Youngman
Michael Youngman
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
