1999 Saab 9-5 Logo
Posted on Jan 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1999 saab no heat driver side
1999 saab 95 no heat driver side passenger and back work
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
761
Points
#9 1999 saab no heat driver side - report.gif post_new.gif 1 Minute AgoYou don't have to remove the dash. You can get to the broken part from underneath. I ordered a replacement aluminum blend door stop arm to repair the plastic one that breaks and it cleared all the heater problems and codes.Usually it is just the stop arm that broke but sometimes after the stop arm breaks, the shaft can fracture also. In my case, it was just the stop arm.
I originally ordered the stop arm from SAABSite for the left side which I found had broken. It worked but I did have a little trouble getting the new part on. I think most of my difficulty was because the manufacturing of the part from SAABSite was not very good. The hole with the keyways was not round but was uneven and rough. It looked like someone didn't use the right tool to drill it but instead bored it out with too small of a drill bit. I've got a little experience in a machine shop and so I was really surprised/disappointed at this workmanship. I had to clean it up with my tools.
After doing all this, I decided to replace the right side stop arm as well as a precaution. I went on Ebay and found and ordered the same type of part... $32. The Ebay item price was much better due to cheaper shipping which was actually A LOT faster getting to me so a win-win all ways around. I was very happy to find the part from Ebay was much higher quality. That is the one I would recommend if you were to buy. However, I also noticed that the motor shaft on my right side had slipped as you describe. At first I pushed it in too far because when I put the cover back on, it would stall... I found the other end of the shaft that pokes out the back was contacting the cover. I repositioned it again and had no further problems.
Anonymous
Level 1:
  • Contributor 45 Answers
  • Posted on Sep 23, 2009
Anonymous
Contributor
Level 1:
Answers
45
Questions
0
Helped
37130
Points
63
This is a problem with the air distribution box behind the dash. Usually a small plastic link that turns the flap breaks. Unfortunately you must remove dashboard and replace the assembly as no repair parts are avail.
Anonymous
Level 2:
  • Expert 83 Answers
  • Posted on Mar 25, 2009
Anonymous
Expert
Level 2:
Answers
83
Questions
0
Helped
58268
Points
173
You have a broken blend door shaft. The solution is pretty cheap according to the saab services website. This is a very common problem on Saab 9-5s.
2004 saab arc driver side central lock not working
Check for a bad switch in the door.
Water leaking from the rag top-door seal joint often drains into the switch, causing a short or bad contact eventually.
2003 Saab 9-3 ARC. My pressure sensor on the drivers side window it tripped so I can't roll up the window all the way. I have to inch it up to the top and if I go to far it thinks something is in the way...
Search Saab forums for your year and model to get advice on the driver's window. Re the heated seats not turning off -- try spraying some WD40 into the switch and turning on/off several times to clean it. If that doesn't work, you'll need to take out the switch and either repair or replace it.
How do i remove the drivers window regulator from a 1999 saab 95?
Once you get the door panel off you have to drill out the rivets to get the regulator out. Why do you want to remove the regulator; did it stop working completely and needs to be replaced or is there another problem?
Water is leaking into the passenger compartment of 1999 saab 95
Get your Heater Core Checked...that is a sure indication.
Heat on drivers side cold on passenger
there is not enough freon in the system or doors problems,check heater funtion to see if it heat all windows,if it work it need to be check with AC gauges or machine for it.
2answers
What is the order for bleeding the brakes on a 1989 900s saab?
start with wheel furthest from master cylinder,then 2nd furthest,etc.,closest wheel last.
Dual heat - only heat on drivers side but adjustable for passenge
The thermostat adjustment control may need to be replaced. Also check the hose on the back for cracks, clogs, or missing.
1helpful
Saab 95 headlights dont work high work and drive lights stay on
IF THE BULBS ARE OK CHECK THE HEADLIGHT MODULE(IT LOOKS LIKE A RELAY, ORANGE CASE I THINK) TRY WIGGLING IT,IM PRETTY SURE THATS IT. THEY GO BAD ALOT ON SAABS. IT SHOULD BE IN THE ENGINE CONPARTMENT
4helpful
No heat on the drivers side
I have the same problem with my 1999 Saab 95 SE. I have done some intensive research on the repair and I have come across a few websites with solutions and they ultimately point to the same one. Your HeaterBox blend door or stop arm is broken it diverts the heat to both sides of the compartment. I had a quick free fix from my dealer from them by setting my temp to HI on both sides. But that did not fix the original problem of having cold air blow on the drivers side no matter which selection your choose to have the air blow, may it be on the windshield, panel or floor, it still came out cold. It is fine on the passengers side, but the tech at the Saab dealership instructed me not to adjust the temperature settings on either side or it might break completely, I think their just trying to tack on $2000 dollars of repairs for something I can fix for $100-$200 or even less than that. You should be able to get the job done in 2-3 hours providing nothing else is broken besides the blend door arm and/or stop arm in your heaterbox. Here is the link I found that will help you fix the problem. Hope it helps and keeps you warm, just be glad you have heated seats for now, without it I think I'd freeze to death in this Michigan weather, lol.
Illustrated Fix
Good Luck and Best Regards,
Gandy Kachucha
Top Saab Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Saab Expert? Answer questions, earn points and help others
