Question about Belling Ovens
Hardwiring in cooker
Cant seem to find what the combined wattage of the ovens is.Running in cables and need to know if 6mm or 10mm is required
  • Belling Master
  • 3,463 Answers
6mm is the norm for wiring in the majority of electric ovens, you could fit 10mm, but it is is not really needed, unless you want to do it that way.
Please rate my fixya solution.
Posted on Jan 31, 2009
Zanussi installation manual
what is maximum wattage of new oven? 4 mm cable will take approximately 24 amp or 6 kw
Aug 22, 2014 | Ovens
Total electrical output
Bad news really, the supply cable you have there is not going to be capable of supply to any type of electric oven and hob like you listed above. Your supply cable is possibly only 2.5mm in size, and not the required 6mm with a much higher MCB at the fuseboard. Get a registered electrician to run a new cable from the board to your cooking area. A single oven takes about 3.2Kw adding the hob rings will take way over your limit. Curry's listing of that cooker as a load of .75Kw or thereabouts is obviously incorrect.
Jan 15, 2014 | Ovens
What size cable is required ? 6mm or 2.5 to install a dual fule belling range cooker
6 is best & sufficient. 2.5 is not recommended.
Aug 17, 2011 | Belling Ovens
HOW TO WIRE A SINGLE INTEGRATED OVEN? Can it be wired into the mains cooker point?
An integrated oven that has a 13 amp plug can be wired into a cooker point without any concerns since you are wiring it into a feed that is capable of handling a greater power requirement than is needed.
For the avoidance of doubt, the other way around, if you are considering putting a 13 amp plug on a unit that is designed for direct hardwiring into a cooker point, you should think again because it is probably capable of drawing more current than the 13 amp socket could safely handle
Jul 19, 2011 | Ovens
Hotpoint bd32 oven and top oven/grill what output does this have .and does it need 6mm cable connection or can it go on a plug
You most definitely need a 6mm hard wired supply cable to cooker, anything less, and the cable will overheat .
Under no circumstances connect it to a 13 amp suupply and plug.
The total kw output can reach in excess of 4-5 kw, so it is imperative that you hard wire it to a seperate fused supply.
Jun 22, 2011 | Ovens
Can I connect my Zanunussi zkc6040x cooker with 2.5mm T&E into my cooker outlet switch that is powered by 6mm and runs about 25`to the fuse box? Thanks.
No. It must be 6mm t&e cable from the wall socket to the cooker. To use anything else will rick getting an electric shock.
Sep 10, 2009 | Ovens
Cant set cooker clock so cant use oven as a result
You will probably have to replace the cooker clock. Do any of the other parts work? This fortunately is not that expensive and you were blessed not to have more damage than this.
Jan 29, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Oven has 4 conductor power cable, moved to house with 3 conductor
Unless your cooker is totally different to the norm, then yes you can use 3 core cable. assuming you are in the u/k, then the following applys.Brown is live-Blue is neutral, andGreen/Yellow is earth.
Depending on the total wattage of the cooker, you will need to use a min of 6mm twin and earth cable, If in any doubt, consult an electrician
Please leave feeedback
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Is 10mm cable ok from 4kw oven to connector unit
A bigger cable size (larger diameter conductors) will not affect power requirements of the stove. (A smaller one definitely will)
Nov 16, 2008 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
135 people viewed this question
Top Belling Ovens Experts
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
