Question about Vertex iTECH iQfive iQplus Yeasu--VX800 Compatible Two Way Adapters 2-Way Radio
V-800 trouble I have a VX-800U and when I programmed it, it took the new info, it will transmit but no audio is transmitted, and no audio is received. It will key up,and will stop scanning when traffic is received Any Ideas?
  • Jeffrey Elrick Jul 31, 2007
    Thanks for all your help, I figured it out. FYI, The radios have an encription board in them. Unless you check the box that says Encr, you get no audio and transmit no audio. you must check the box for All programmed channels.
    Thanks again Jeff
  • Anonymous Apr 05, 2008
    Have a continuous alarm sounding. Also need to reset to primary channels.
When i turn on my radio it keeps beeping repeatly nothing else happens
Posted on Jul 21, 2008
    Problem Solver:
  • 20 Answers
I agree with everone here..... check that your not programmed for tones. If you programmed the rx freq right but programmed in a tone... you won't hear a thing until the txing radio has that same tone. I can't remember the exact programming for this radio...... but if you can add in a squelch off/on or monitor on/off button try that. If your sure the txing radio is on freq. and your sure the radio is programmed to rx that freq... then hit the squelch on/off button so you can hear everything. This will temp. disable the tone squelch if you happened to programm it that way. Also check your squelch programming... again I can't remember this radio exactly but its possible the squelch could be set too high if its programmable. It most likly won't help you out too much.... but good luck anyways Take care
Posted on Jul 30, 2007
    Problem Solver:
  • 12 Answers
Hi ive not worked on this radio but i would go with what Neto says have you programmed it right IE Sq CTSS Mic Gain Ect
  • 123 Answers
Did you programmed with carried sql? How do you know that is transmiting and reiciving, may be you are not using the rigth code sql (ctcss or DPl).
SOURCE:
Will transmit but will not receive
I have programmed hundreds of these. The radio may be receiving, but the speaker may be muted. If using a hand mic, have the mic "off hook" or ungrounded and try again. Does the front light flash while the radio is receiving? This indicates the radio is "hearing", just not passing the audio to the speaker. Is there something plugged into the audio jack in the back? Let me know. In 20-30 minutes most shops familiar with Vertex will know exactly what is happening.
Oct 01, 2015 | Vertex Standard VX-2100-G7-45-PKG-1 UHF...
Will not transmitt
Are you programming the radio or did you buy it used? In the programming, a radio can be set for receive only. The other possibility is a bad battery. A battery has a huge draw on transmit and may not actually send a signal. Think of it like trying to start a car. I encounter this issue weekly. (poor battery) Post more information if you want me to help you. Such as: do you have the software, is it a fresh battery. How old is the radio. Let me know.
Feb 02, 2014 | Vertex Standard Vx-231 Vx231 Uhf...
Vertex 2200 transmits but makes no sound
You mean NO Audio Transmit?
If there is No Audio at PTT Bad MIc Cord.
Change the Mic cord.
Dec 01, 2013 | Vertex Cd Vx-2200 Vx-2100 Series...
My vertex vx-2100 receives but will not transmit
Hi Rich,
Here's the solution to your query: join yahoo group specific to your radio Make/Model, the team of experts will only be to pleased to assist you, plus you can have downloads, free.
I hope this sets you right.
Best regards,
Peter
Jan 07, 2013 | Vertex Cd Vx-2200 Vx-2100 Series...
I have two motorola aux4100 radios. I can not get them receive. When I key it up to transmit, the red LED of the transmitting unit comes on and the green LED on the receiving unit comes on but does not...
I would guess you have a PL set on the receive side, and not on the Transmit side. So the audio is being blocked by the PL (as it is supposed to be!) Check your programming, make sure you have the same PL on tx and rx.
Jun 03, 2011 | Motorola AUX4100 2-Way Radio
None of my programs are receiving midi commands from the FC-300, it's linked into an M-Box II.
I have a FC-200. I don't know by your post what you are trying to do but think of the pedal as a device that can alter a communication between two other devices or one device which transmits info which the pedal receives, alters and then transmits to whatever is on the receiving end. In this case your program. The pedal has to have sysex info transmitted to it or midi info such as a sequence etc. I use mine to control the parameters on my wind syth module. I go from midi out on the module to midi in on the pedal and from midi out on the pedal to midi in on the module. There is also a battery onboard that you might want to check that stores your pedals programmed parameters. Hope this helps.
Aug 30, 2009 | Roland Fc300 Guitar Foot Controller
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Trouble transmitting & receiving on uhf.
While there might be a multitude of answers to this question. The first would be the radio is in need of repair, or not programmed correctly.
Jul 07, 2008 | Uniden Radio Communications
Vertex iTECH iQfive iQplus Yeasu--VX800 Compatible Two Way Adapters 2-Way Radio Logo
305 people viewed this question
Top Vertex Radio Communications Experts
eradiostore
eradiostore
k24674
Sheldon Dedek
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
