Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman lawn tractor will not start/turnover
Started fine. tried to engage blades and it died. it will not do anything start or turnover. checked battery and starter,ok. safety switch seems to be working, do not know how to check the switch itself. there is a white wire coming out the harness that isn't connected to anything but doen't see where it should be connected.
  • 1 more comment
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mr b, i need to know does mower have one or two cyleinders,do you have a electric pto clutch or manule,also need model number from mower body can't look up any thing with out it.please let me know,thank you.MrFixIt.
  • joe May 11, 2010
    will it try to start when its in neutral? what about in neutral and foot pedal depressed?
  • Al Perry May 11, 2010
    Unplug the seat switch and put a jumper in the wire conector. This will complete the circut. See if the tractor will start.
  • 23 Answers
Are you sure the safty switch is working. It sounds like its in the seat switch or the pedal switch.
You can sometimes jump these switches over with a paper clip or small metal wire to make contact on each side of the plugin.
this being on the machine side.
Also PTO cluth may be seized. in the on position locking up the motor. and blades.
Posted on Feb 03, 2009
What do I need to check to activate starter will not engage. Engine will start but dies when blades are engaged
If your mower runs fine, but dies when the blades are engaged, that has nothing at all to do with the starter - or with the engine. There is a malfunction is in either the electrical system, PTO clutch or one of the safety features somewhere. Check all of the belts first for wear or breakage, then if they're OK, you probably need a small engine mechanic, but it doesn't sound really serious.
Jul 02, 2017 | Kohler Electrical Supplies
Why does my riding mower die when put in gear or engage the blades
Check out the grass box safety switch. if not fully depressed it will apply brakes to the blades when in gear. Most mowers are designed with a safety switch to stop the blades, or forward motion if the grass box is not fitted correctly.
Aug 23, 2015 | Garden
Tractor tries to die wen i engage the blades
is a bad safety switch shutting it off?start with the one on the seat
May 17, 2012 | Craftsman Garden
I have a craftsman mower with the B&S 21hp Intek OHV motor, it starts fine but when you go to engage the blade or go forward or backward or release the parking brake it will die unless you disengage...
Check the switch on the seat, of all places. There's a safety switch on the seat that will kill the engine if it's not engaged when do anything other than start and run the engine.
If the switch checks out, get back with me.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
YARD MAN 42 '' RIDEING MOWER WON'T START PROBABLY SAFETY PROBLEM
safety switches that all riding mowers seem to have include a seat/brake safety which means that you have to be sitting in the seat or the brake must be engaged for it to start. also there is the blade engaged safety, which means the mower will not start normally with the blades engaged.
if you meet those conditions check the switches themselves
non safety related, do you hear a click or a clunk when you turn the key to the start position, this is the starting coil pulling in to send power from the battery to the engine starter, all safety switches will interupt power from the key switch to the starting coil
if you hear the coil energize and the engine does not start you have low battery voltage or loose connection or some other mechanical problem
Jul 03, 2011 | Craftsman 25cc Gas Line Trimmer
All the mower will do is click when trying to start. Battery is fine I took out and had it checked
starter solenoid,switch ,starter,fuse, or one of the safety switches--seat,blade engage satety, need to check the wiring or connections but start with the inline fuse than solenoid these two are the most common problem after a dead battery
Feb 02, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2135 wont start
check for a fuse behind the ignition
it might be blown
then i would check the starter solenoid
if you put a screwdriver accross the bolts that hold the wire from the starter and ignition switch and it tries to start there's ur problem.
Jul 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Older Craftsman 43" 17 HP Briggs
Check to make sure battery is above 12.3 volts, secondly bypass the solenoid to the starter by using jumper cables and see if the starter works, if so, you sureley have a safety switch problem, I beleive you have five on this model,
good luck
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Yard machine riding mower will not start
check all of your known safety switches!
Clutch has to be pushed in
seat switch (sit on mower)
blade disengage switch
Finally check your starter soleniod between the battery and the starter and look for fuses and check them out in the process
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Starter motor won't activate
Had the mower blades engaged and there must have been a safety switch engaged.
Apr 18, 2009 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
267 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
