I got consaw stihl ts400 problem, my saw wont start, it starts with every pull but only for one cycle, gave new filters sparkplug, checked compresion and so on and its same, just cant fix it, plug comes out wet and smell of petrol, spark is there too, every time pull it starts for one cycle only
SOURCE: Ts420 stihl cut off saw
the jets in the carburetor need to be cleaned out very well to operate this engine
the holes in the jets are very small and clog up easily with in a year or two
SOURCE: not getting spark when starting
[email protected] HI GRYDERT your problem could be your on, off switch. This might sound funny, but switch the on off switch real fast several times, then see if you havee fire. If not check your spark plug. If you have a n
ew one try it. If that don't work check the connection at the plug to be sure it is makiong contact with the plug. If all this does't work you will have to go inside to the coil. They don't usually go ba d but it could. But first check to be sure it isn't grounded at the small wire from the switch. Good Luck.
Clean the air filter and check that the choke is operating correctly.
I have exactly the same problem on a TS400 if somebody can help mail me at [email protected]
