Venta Airwasher VS370 2 Gallon Humidifier
Problem for Venta Airwasher VS370 2 Gallon Humidifier
Venta Airwasher Display Light Blinking...
By micah808 on Jan 30, 2009
Hi, I just changed the maintenance free box on my venta airwasher, pressed vapor and humidity buttons to clear the "change" sign, filled the tank, waited 30 seconds before turning on the unit and now it simply blinks on the display...no mist. Can you help? Do I need to send it back? I have tried unplugging it, taking the new box out and re-inserting it, and messing with the level of vapor/humidity requested. Thank you in advance!
Solution #1
posted on Nov 21, 2009
Not Rated)
591QES
Rank: Apprentice
Rating: 0%, 0 votes
same problem here too!
Was this helpful?
Yes
No
Solution #2
posted on Feb 03, 2009
Not Rated)
stmurphy98
Rank: Apprentice
Rating: 0%, 0 votes
This has happened to me. Check the contact points in the base of the machine. Ours had some corrosion on them. I took an emery board and filed the corrosion off to clean the contact points.
Was this helpful?
Yes
No
Solution #3
posted on Jan 30, 2009
Not Rated)
MNfisherman
Rank: Wiz
Rating: 85%, 2690 votes
Do you have an owners manual? There might be a reset code. I would look at that first. If it does not have a reset code, then yes you should return it.
Was this helpful?
Yes
No
Popular Solutions for Venta Airwasher VS370 2 Gallon
Questions and Unsolved Problems for Venta Airwasher VS370 2 Gallon
Do you recommend Venta Airwasher VS370 2 Gallon Humidifier?
Answer
Answer
water valve stays on all time 2001 model
Answer
how do I know if my Aprilaire Humidifier - Model 550 is working? I need a booklet
Answer
brand new out of box display will not stop blinking this is the second unit I got from the store and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Venta Airwasher VS370 2 Gallon...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2520
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
