Question about Canon PIXMA MP210 Photo All-In-One Printer
E3 error code
Error code E3 indicates paper jam but I can't find any paper jam
  • Anonymous Feb 15, 2009
    Tried your tips with the envelope with no success, I'm afraid. Problem began after changing ink cartridges. I can see nothing that could be jamming. This is a Canon MP210--where is the manual feed button?
  • jacque77 Feb 17, 2009
    I've tried ALL of the above, over and over...
    There is NOTHING obstructing visible obstructing it; I've successfully feed paper through but it then off it goes...
    It was working fine then I ran a print job that ran out of paper and I have not been able to get it to work ever since.
    I've tried different sizes, card stock, you name it but it still keep coming going off line E3~
    I'm ready to dump this printer! Thanks for ANY help you can give!
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 31, 2009
  • petrunkov Feb 24, 2011
    Sure, there was something (I don't know what) on the feed way - so what it helped me was a piece of hard paper (cover paper from the box of special print papers) and manually with a little bit of force push this paper through - and it works!! (As I said, there was something unvisible on the feed way)
I had a paper jam a few days ago. Turned printer off then cleared jam and when I turned it on again it still had the E3 error code indicating it is still jammed. There is no paper in it anywhere. I have...
Check the paper feed tray for bent papers. Also, try blowing over the sensors to clear any debris. Check for small pieces that may have been left behind. If all fails, unplug it from the outlet, then start it up. Good luck!
May 06, 2017 | Xerox WorkCentre XE90FX Laser Printer
Error 3 indicated - what is it and how do I fix it
E3 means that there is a paper jam. If you are getting the E3 error and there is not an actual paper jam you may need to do is simulate a paper jam. Try inserting paper crooked to cause a jam so that when it starts trying to feed the paper through it gets jammed. Then lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Mar 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I've got error code E3 and someone at Canon
unfortunately, no. Canon will not sell you the parts for repair. They only sell to authorized repair centers.
Thanks for using FixYa - a 5 TUHMBS rating is appreciated for answering your FREE question.
Nov 30, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
My canon pixma mp150 have an E3. How can I fix
The E3 error indicates paper jam. If there is no paper jammed then look that if something is stuck inside the rollers. This may solve your problem.
Aug 31, 2009 | Office Equipment & Supplies
Getting code E3. What does this mean?
error E3 means Paper jam ..try to clean any paper inside...
May 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Flashing E3 error code for a paper jam
I had the same problem with my mp 160, Error message was blinking. I tried to print but the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbord(I used a magazine cover), cut it in a size of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine. Hope it does for you.
Mar 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer Error E3
E3 error -
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [Black] or [Color].
The above is direct from the user manual.
If there is no paper jam - look for any small pieces of paper that could be located near the roller sensor.
Oct 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
E3 paper jam
if the paper is crooked it will come out wrinkled. If not the print is crooked indicating a different problem.
You wil have to look at the paper as it is printing, to see where it is catching, paper ramp maybe ( before the fuser entrance), exit rollers? ( only place I know there are bristles)
E3 is : paper jam in fuser
also check fingers or claws on fuser they catch the paper if worn.
Apr 21, 2008 | Office Equipment & Supplies
Canon PIXMA MP210 Photo All-In-One Printer Logo
2,881 people viewed this question
old marine
old marine
