Question about Dell E171FPb 17" TFT LCD Flat Panel Monitor
Monitor fades and turns blue
I have a E171FPb flat panel from dell. It's about 5 years old. At times it begins fading at the bottom. The fading moves up the screen. Then the screen begins turning solid blue at the bottom right corner. This too moves up the screen. However, if I turn the monitor off and right back on, the fading/blue screen is gone and everything looks great. This lasts about a couple of minutes then the fading starts again. Also, after using the computer for a while the fading just stops.
Any ideas?
  • 558 Answers
This sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Posted on Feb 04, 2009
Using the contol buttons on front panel
You did not give a lot of info in this.
was the monitor old (many year) did it happen slowly or not.
is it even on all surfaced or darker on one side?
faded : no contrast or darker?
From the point vue I get, seem to be the neon lamp one maybe shot or not working a 100%
with year, the neon lamp loose brightnest. they even get yellow a little bit (if you compare a new monitor with an old one (white area) the old always fade in the yellow. )
Jan 03, 2014 | Dell Computers & Internet
17" flat screen not displaying
This message "safe mode press any key" sounds more like the problem is in the PC. You need to try another monitor with this PC, also try the monitor with other PC. Need to narrow down the problem first. Plase post back.
Apr 08, 2010 | Dell E171FPb 17" TFT LCD Flat Panel...
My Dell flat panel monitor #1704FPTt will not stay lighted for more than 1 second. It started fading when first turned on about 2 weeks ago, otherwise it has been fine. Can it be fixed (it is about 8 years...
Fist place to check will be the power supply, look for bad caps with bulging tops, check to see if you do have 12vdc feeding the back light inverter circuits, see example of failed monitors (90% are due to bad caps): http://s807.photobucket.com/home/budm/allalbums
Jan 20, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
My flatscreen dell monitor fades out to dark gray, sometimes pink
Its definetely the monitor thats having a problem. when it blacks out during th monitor self test. i suggest you can ask for a replacement monitor.
Mar 19, 2009 | Dell E193FP 19" LCD Monitor
Dell E171FPb 17" TFT LCD Flat Panel Monitor Problem
The LCD and or the LCD inverted has failed. it is an unfortunate fact of life that nowdays it is cheaper to replace that monitor that to aquire parts for repair
Here is one on Ebay:
http://cgi.ebay.com/Dell-E171FPb-LCD-17-Flat-Panel-Color-Monitor_W0QQitemZ290290215133QQcmdZViewItem
You can buy a new 19 for about the same price
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254009
Jan 21, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Monitor gets brighter
Well... it's time for a replacement. It's seems your AD Board begin slowly to dies out... Eventually will turn to white screen.
You'll need a new AD Board.
Mar 10, 2008 | Fuji FP-768 17" Flat Panel LCD Monitor
Dell AS501 flat screen monitor
The front panel switches seem to be the culprit.
If you are technically sound you maybe able to solve problem by opening monitor and clean front panel switches or replace them.
Samir.
Feb 28, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E171FPb monitor turns on, but that's it
Hi Letneper,
Hope this will give you hints. Some monitors have standby mode or screen saver feature and or self test feature when not connected to video input of your PC or CPU. Except this problem did not occur at first use. You can turn this off like other monitors manually at OSD (on-screen display) settings if available. No more no less if it works fine with PC or CPU on then there's nothing to worry.
Best regards,
Rosener Guyano
Sep 04, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Dell E171FPb 17" TFT LCD Flat Panel Monitor Logo
305 people viewed this question
Alun Cox
