Question about Toshiba SD-3980 DVD Player
Toshiba DVD player will not power up - totally dead, but fine last time it was used
  • just4kicks Jan 31, 2009
    I have the same problem. I checked the fuse it seemed okay. Then when I went to take it out again it shocked me so i know the power supply is not shot, so now what
  • palmeraaa Apr 27, 2009
    Same trouble: No power up. Power supply voltages are not good/missing. Where can I get a replacement power supply board?
  • 11,896 Answers
Either the fuse under the cover is blown, or your power supply is shot. check the fuse first, by removing dvd cover.
Posted on Jan 30, 2009
Completely dead laptop.
sometimes you just need to remove the battery then power-up the unit using its charger.
Jul 05, 2013 | Toshiba satellite c660
My Toshiba SDP93S portable DVD player won't work.
The power supply adapter may be dead, should be tested, if okay! remove the main battery will load player down in some cases. If still no result! cheaper to replace than repair.
Apr 02, 2012 | Toshiba SDP93S Portable DVD Player
Our toshiba mw20f52 tv/vcr/dvd won't turn on. It worked fine last night. Is it fixable or dead? Should we try anything in particular to "jump" it? And there are a dvd and a vhs still in it! ...
You may have blown a fuse in which case something else inside is probably shorted. Check diodes and transistors near the blown fuse if you know how. If you're not comfortable working on electronics I would check the phonebook for a hometown TV repair shop. They may be nice enough to retrieve your movies for you at a minimal charge and maybe give an idea of how much to fix the set. Good luck.
Apr 28, 2011 | Toshiba MW20F52 20" TV/DVD/VCR Combo TV
Totally seized up
the power supply of your dvd player is deffective,try to change the filter capacitor or the small capacitor of your power supply board.(
Mar 10, 2010 | Televison & Video
Won't play any DVDs
I mostly first always recommend a dvd lens cleaner to clean the lens incase there is something on the lens.
Is the player underwarranty? the lens may have a issue other than dirt and might need to be replaced.
What happened last time it worked fine? try unpluging the dvd player for 5 minutes and try again.
Jan 04, 2009 | Toshiba SD-6980 DVD Player
Try using a DVD lens cleaner
Sep 10, 2008 | Toshiba MW27H62 27" TV/DVD
Onboard LCD display
did you try to insert a different cd? see the settings like OSD button on the remote control or display to view the tracks.
Sep 13, 2008 | Toshiba SD-4900 DVD Player
Wont read divx on cds
I have had this same problem on my Toshiba. I went through the Control Panel and their were settings for the dvd player it used. You can change settings and they sometimes change automatically.
May 22, 2008 | Toshiba SD-K760 DVD Player
Completely dead
Hi This is my opinion only, but I have worked on many many DVD players, and if you don't need anything fancy, then go for the $30.00 unit. Actually, I would look for something in the $50.00 range, as the $30.00 units are very cheaply made. I have often worked on a $100.00 unit, followed by a $50.00 unit, which had the exact same laser and mechanism inside, the only difference being the brand name stamped on the front. But.... You could purchase three $30.00 units, for $100.00 and if you used them one at a time until the last one died, I dare say they would very likely outlast the $100.00 unit by far. I've probably just confused you now, so I'll just end by saying that on a regular t.v., the picture will look just as good using either option, and you can have good luck or bad luck with any piece of electronics expensive or not. Good Luck!
Aug 12, 2006 | Toshiba SD-3980 DVD Player
Toshiba SD-3980 DVD Player Logo
680 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
