Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Power good no green light no subs
Power good--new battery--no green light--no subs--all fuses look ok
  • farrellp629 Jan 30, 2009
    thanks --amp was working new for about a month---hyponics and power light are not on--but the small blue lights are
    Problem Solver:
  • 16 Answers
I have the same problem. I took it to a local repair shop and was told that the problem is one of the boards that come off of the main board. Hifonics does not sell those directly to people so you would have to send in for repair. For the prices that they sell for now, its just better to get another Hifonics amp. They are great when they do work.
Posted on Feb 13, 2010
  • 11,896 Answers
Make sure you got a good ground. do not ground on painted surfaces! If you got power from battery, check the remote wire running to cd player. Hook up remote blue wire with the one for cd player. If you still have a problem and the fuse is good, then the amp is fried
Posted on Jan 30, 2009
Everything did work but kept blowin fuses by the battery. Now a red light stays on, on the amp & the blue/green power lights dont *** on. What should i do?
Check all of your power connections, your speaker connections and battery connections. if all are good and clean (no shorts/wires touching) then try unhooking your speakers and see if the lights come back, if that helps then you have problems with your speakers, if not then amp is bad. I hope this helps ya.
Randy
Feb 17, 2011 | Phoenix Gold Titanium 800.1 Car Audio...
No Power
hiya
if u change the fuse inside the actual sub shud power up ok
Rik
Feb 26, 2009 | Sunfire True Subwoofer Mark IV Subwoofer
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
Jun 05, 2010 | Car Audio & Video
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Sound went completely dead on an 07 Crown Victoria. I checked all the fuses and all are good...plugged the original deck back in and still no sound...nothing..completely dead..all connections look good...
Be sure you checked all 3 fuses, F3 5amp, F9 7.5amp. F12 15amp. Test with test light the red and black wire in start, the dark blue and light green in accesory, and the violet hot at all times. These are all in the harness to the radio. Then test grounds by clamping the test light to battery positive, and check the black wire and the two black and light greens. If both units are good, there's gotta be a bad power or ground.
Aug 12, 2009 | 2008 Ford Crown Victoria
HiFonics txi4008 not working, partially lighting up
Sounds like your amp has some power supply compents shorted out. Maybe some of the power mosfets are shorted and your only getting a little bit of power. That why only the H is lighting and as far as the green light, it don't take much for it to turn on. If it was major it would go into protect mode but it is'nt. I repair amps for a living and I'm the cheapest you'll find. But if you know about electronics and think you can take a crack at it, check it out. Becareful you could do more damage. Let me know if your interested. skinnman33@gmail.com
Jun 06, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Subs stoped
Any sub can be blown in 30sec if given bad clipped power, so just measure them with a multimeter and see if the coils still have resistance. Throw away the test light and only use a multimeter.
Apr 14, 2009 | Boston Acoustics Competitor 1200 Car...
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Shuts off after playing music
i had the same problem, apperantly creative made an error making the hardware for the subwoofer, and put in an mos-fet with to little resistance, i called creative and gave them the serial number behind the subwoofer and they sent me a new one that hasnt acted up yet.
Jan 13, 2008 | Creative Labs Gigaworks S750 Computer...
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
301 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
