Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 210 Pro not oiling chain
Is there a gear that oils the chain on the Poulan 210 chainsaw??? and if so do you have the manual or instructions to replace it?? Any help would be great
    President:
  • 2,976 Answers
Make sure the oil port doesn't have a chip of wood blocking it.
Posted on Jan 30, 2009
Poulan pro troubleshooting
CHAIN STRETCHS AS IT HEATS - KEEP CHAIN TIGHTENED CORRECTLY AND ALWAYS KEEP OIL IN OILER AND MAKE SURE IT OILS THE CHAIN. IF THIS DOESN'T FIX - REPLACE THE CHAIN. IF IT STILL HAPPENS THEN REPLACE BAR. WILL FAIL AGAIN WITHOUT OIL. POULAN WILL NOT HOLD UP WITHOUT CHAIN LUBRICATION. WORSE THAN OTHERS. IF CHAIN OR BAR OVERHEATED YOU'LL WORK ON IT MORE THAN YOU CUT. OIL IS THE KEY TO CUT WITH A POULAN!
Aug 10, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
My poulan pro chainsaw dies when I give it gas and I think the bar and chain oil is leaking out during storage.
try and run it with the muffler off the build up with carbon and restricted the exhaust flow as for the oil leak mine the screws became loose behind the clutch for the oil pump
Sep 17, 2012 | Poulan Pro 20-inch 2-cycle 50cc Gas...
No oil getting to bar and chain..
The oil pump is run by a worm gear that will strip easily if the oil pump becomes clogged. You'll have to remove the bar and do some disassembly on the saw, but it is possible to fix. You can buy the replacement parts kit (that comes with an instruction sheet) from poulan for about 20 bucks, just call the number on the saw.
Sep 05, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan is not sending oil to the chain, i tried taking air to it and cleaned it out.
The oil pump has a worm gear that strips easily if the oil line clogs. You will likely need to replace it.
Aug 30, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need a manual for a new Poulan 3.5 electric chainsaw, or, failing that, I need instructions on what kind of oil to use on it, and whether I need separate oil for the chain.
You shouldn't need any other oil than the oil to keep the chain and bar guide oiled (pressing down on the button adds more oil to the chain/bar). You can use standard Bar and Chain Oil, or probably pay a little more and use the Poulan brand oil, but in my experience, any bar oil for chainsaws will work, and the larger the container you buy, the less per ounce you will pay. Remember this is NOT an automatic oiling system, so it will be cheaper in the long run to remember to press that button than to replace the chain/saw if it overheats.
Aug 29, 2011 | Poulan 14" Electric Chainsaw
My Poulan Pro chain saw (model # PP4620 AVHD) doesot move B&C oil from the oil reservoir to the chain. How can I repair this?
If the ports where the oil comes out aren't clogged, you will have to order a oil pump and then take apart the saw from right underneath the bar. The oil pump is run by a worm gear that strips easily.
Aug 22, 2011 | Poulan Pro Chain Saw 46cc 20"
I bought a reconditioned Poulan pro PP4629AVX and I can't find a manual for it. What is the oil to gas mixture? Thanks Steve
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas.
Sep 25, 2010 | Poulan Pro Chain Saw 46cc 20"
How much oil for a poulan pro Chain saw?
if it is 50 to 1 use 2.5 ounces of 2cycle oil per gallon of gas
Jun 30, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw Bar Chain Oiler Stopped Flowing
The filter can usually be caught with a hooked wire and drawn up far enough to deal with the filter. Oil filters are not prone to plugging unless the oil used is contaminated. If you run the engine without the bar and chain attached, oil should ooze out of the engine side port. If nothing, suspect problems with the oil pump. Some saws use a plastic gear in the pump and can strip the teeth of the gear. You should find it located behind the clutch assembly. Once you have oil flowing from the engine, clean the bar drive-end oil ports that go from the large holes out to the chain groove on each side. Finally, run the bar tip near some cardboard--it should throw off a thin line of oil. I have no idea what the plastic tube might be (a manual pumper perhaps?). Hope this helps!
May 23, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
472 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
