Question about Gateway Computers & Internet
In having problems with connecting to the internet
My Internet provider came to my home to set up the internet to my desktop however he says that Im unable to connect due to my network adapter not being installed. It was before I switched providers but now I see a yellow question mark with the words Ethernet Controller listed. How do I correct the problem without going out to buy a wireless adapter?
    Genius:
  • 1,605 Answers
Go to control panel>>system>>hardware manager.
uninstall the ethernet controller.
restart the PC let eh machine find the driver.
or you can find a working PC and download the NIC driver for your PC.
Posted on Jan 30, 2009
My compaq presario 5240 w/ win 98 wont connect to the internet
make a menu on top toolbar right click in top toolbar
select menu bar this will add file edit view fav tools and help
click on tools then from the drop down list internet options connections tick in never dial a connection
then you will have to add your isp internet service provider
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up usb or
an ethernet connection to connect to the internet or
if you have a laptop you can choose a wireless usb modem
which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
hope it helps
Jun 18, 2012 | Compaq Presario 5240 (353200-003) PC...
I am unable to connect to the internet. I am asked for a password. where do I find this. The unit is an archos 7 home tablet
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Mar 14, 2011 | Archos 7 HOME TABLET V2 8 GB Hard Drive
My pc will not get on the internet . im thinking the windows explorer was erased. what do i do?
to get an internet connection you will need an internet provider which will provide you with a modem and an installation disk which will connect you to the net internet explorer will be on the disk provided
hope this helps
Oct 24, 2010 | Dell Dimension 8200 PC Desktop
Im not getting internet on my p c but im getting it on my laptops time warner said tell you to reinstall internet connection
Go into control panel, network connections and delete or remove the existing connection, reboot and then go back into control panel, network connections and click on new connection or set up a small home or office network. Run through the wizard and everything should become clear..
Mar 13, 2010 | Computers & Internet
Cannot connect my laptop to internet through router wrt54g v8
Make sure you have ipx and spx protocol installed, and a home network setup through windows. Also if the first try don't work make sure you firewall setting is not blocking your router.
Dec 03, 2009 | Linksys Wireless-G WRT54G Router
How can i connect to the internet using my switch??
Basically Internet connection required a networking connection for multiple number of PCs.There are 5 types of network connection and most simple and common network connection is Local Area Connection.You can use Windows Xp or Vista for your OS, when connection was made set up your lan from your internet server from cd provided by DSLinternet server.You should Have one PC server for your multiple PC as the administrator.If your inernet was configured from your PC server(as administrator) Share your internet using your LAN in each PC using Windows xp follow set up networking clicking additional task and click Home and office networking then follow wisard set up.You Have now internet connection in your multiple PC.
Feb 24, 2009 | Computers & Internet
My laptop will connect with the internet though a home router. At a hotel or airport it will not connect with the internet service provided by these places. What is wrong
More information needed:
Does your laptop have a wireless adapter?
How do you connect at home? (wireles or ethernet cable?)
What brand of laptop do you have?
What troubleshooting steps have you already taken?
For your information, when away from your home network, you must change your wireless settings to point to the hotel or airport provider where you are trying to connect.
Usually hotels have some contact information and some basic support (some better than others) for their wireless connections.
Dec 29, 2008 | Computers & Internet
Xbox live on this laptop
I assume you have a crossover ethernet cable.
put the my network places on your desktop.
right click on desktop/properties/desktop/customize desktop/tic
then on the network places icon on desktop right click/properties
right click on wireless and bridge devices
they are now sharing the same ip
be sure and remove /delete bridge when not sharing as the ip will stick forever likely.
that should do it if you need more info /open my computer and hit help and search for internet connection sharing as the firewall may need to be configured.
Jan 30, 2008 | Sony VAIO PCG-K35 Notebook
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
