Question about Akai LCT2716 27 in. LCD Television
AKAI LCT2721AD remote signal not working
One day my remote control for my tv combo, just stop working. i bought a rca uni control and i didnt work, though it didnt support my tv, went and bought another control and decided to use another tv to test it on and it works. so i am geared to believe that something is wrong with my tv signal.
  • 3 more comments
  • Anonymous Dec 06, 2007
    I lost my remote and bought a sony and rca universal remote and none of them work. Any idea how to solve this problem?
    Thank you
  • Anonymous Dec 16, 2007
    purchased three different remotes and each time you can get one signal out and then it quits working
  • Anonymous Feb 16, 2009
    hi I have the same issue... Retrohack: Can you provide us some picture on how to dissasemble this tv and where inside is the correct solder point, since I know how to solder, him correct with the solder fix but I never dissasemble an lcd tv and I dont want to mess it up... Stonedge
  • Stonedge Feb 17, 2009
    hi I have the same issue... Retrohack: Can you provide us some picture on how to dissasemble this tv and where inside is the correct solder point, since I know how to solder him correct with the solder fix but I never dissasemble an lcd tv and I dont want to mess it up... Stonedge
    hi I have the same issue(but with an LCT3201ADC)... Retrohack: Can you provide us some picture on how to dissasemble this tv and where inside is the correct solder point(Did I need to only remove the back panel or did I need to completely dissasemble every part of the tv to acces the solder point?), since I know how to solder, him correct with the solder fix but I never dissasemble an lcd tv and I dont want to mess it up... Stonedge
    Scholar:
  • 27 Answers
This model is notorious for ring cracks in the solder joints on the IR sensor inside the television unit itself. The problem seems to come from pressure being applied to the board during installation. I have repaired three this month! It is a simple fix (just have to reheat the solder joints) if you know how to solder.
If not, the unit will more than likely have to be serviced by a repair tech.
Hope this helps you out.....
Posted on Oct 21, 2007
  • Jerry Coleman
    Jerry Coleman Oct 21, 2007
    By the way, if you are ever in doubt about your remote control itself, use a digital camera to test it ( like the one on a cell phone). If you point the remote at your camera and hit a button on the remote, the infrared signal will show up on your camera screen as visible light. It's a good tester and can save you some $$$!!!
    Good luck.....
    Retro
Try checking to see if the springs for the battery contact have flattened and no longer make contact. Check BOTH the "+" and "-" sides.
Posted on Aug 11, 2007
SOURCE:
I have a AKAI LCT3701AD 37 inch TV don't have the original remote control but bought a universal remote control but is not working Why?
YOU WILL STILL NEED TO PROGRAM THE NEW REMOTE FROM THE MANUAL THAT CAME WITH THE REMOTE. NORMALLY THIER ARE TWO WAYS TO PROGRAM A REMOTE EITHER MANUALLY OR TO DO IT AUTOMATICALLY. YES THE ORIGIONAL REMOTE IS ALREADY SET UP FOR YOUR MODEL OF TV BUT WITH THAT SAID TRY TO PROGRAM IT BY BOTH PARTS OF THE MANUAL. i AM USING A 55 INCH SMART TV AND HAVE DONE THIS AND ON OTHER SMART TV'S. ALSO YOU CAN GO TO THE WEBSITE OF THE REMOTE THAT YOU PURCHASE AND LOOK FOR VIDEOS ON HOW TO SET IT UP. IF YOU NEED MORE HELP LET SOMEONE HERE KNOW. GOOD LUCK.
Jan 23, 2017 | Akai Televison & Video
I bought 2008 Subaru tribeca and the DVD remote si not working so i bought a new one from Subaru but it's still not working but the unit is ok any idea?
remote volume control not working Questions & Answers ...
www.fixya.com > Forum > Tags
I bought a Philips PM3S universal remote contro today, thinking that the TV needed one specifically. After one code try, . ... Volume buttons of Sony Remote control is not working for Akai TV. ... not working for Akai TV ... Radio volume control on 2008 Subaru Tribeca does not ... www.fixya.com/. ... RCA TruFlat 27F520T 27" TV.
Media Center Entertainment for Tribeca - SB9T.com
Nov 23, 2015 | RCA 3-Device Universal Remote with...
My AKAI tv/dvd combo - DVD quit working.
Most times it's video read issue such as a dirty lens on the laser.If you smoke in the house or use a fireplace there is a lot of airborn stuff to leave a slight haze on the lens making reading the disk impossible.Try a standard cd or dvd lens cleaner.The on that looks like a cd and uses alcohol on one of the cleaning brushes on the disk you've got a 50 50 chance.
good luck
Rich
Jun 06, 2010 | Akai LCT2721AD 27 in. LCD Television
Akai TV remote is not working correctly
I don't think the Akai remote is designed to work with cable or satellite service. I have to use both remotes & I have Direct TV.
Try unplugging the TV for a few minutes then plug it in and try the remote again. I had the same problem shortly before my Akai LCT2721AD quit working altogether. Three 1000uF capacitors blew in the power supply. Bought 3 new ones and replaced the blown ones myself rather than pay over $100 for a new power supply. Works fine now.
Oct 23, 2009 | Akai LCT2721AD 27 in. LCD Television
IR sensor problem RCA T25208
You need the proper CODE associated with the Remote.
When doing a set up of the remote, the device (TV I assume) should allow you to put in a code number for that device. It should be listed on the insert manual that came with the hand held remote. Could be in the last few pages.
Jan 31, 2018 | RCA T25208 25 in. TV/VCR Combo
Model crcr4383 won't provide a code for Awia tv dvd combo unit
If you have a Universal RCA remote, go to remotefinder.com/default.aspx?site=rca and you shoulkd find the proper code.
Oct 27, 2008 | RCA Universal Remote Control
Dishnetwork Remote
the way i program a remote is hold the tv botton on top for five sec. till all lite up on top, then press tv power botton (little red)then slowly channel up till tv turns off, then press pound to set. some combo tvs wont take
Jun 11, 2008 | Akai LCT2716 27 in. LCD Television
Lost remote for akai tv/vcr/dvd set
I think you should look over the Internet to buy one from places like Ebay for your brand of TV.
Apr 07, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
I can't program my universal remote to my tv
I found these codes for this Akai (in which I'm totally dissapointed) and successfully programmed my DirectTV remote using 11675. Good Luck,
Mar 18, 2008 | Tivo DirectTV Remote Remote Control
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Akai LCT2716 27 in. LCD Television Logo
845 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
