Question about Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Display powers of with power up of AVC
Unit is five years old and until now no problems. Following suggested power up process (1) dispplay Main Power on yields red to blinking red expected. (2) AVC Main Power on and Display red goes off. Attempts to immediately repeat sequence yields no red light on Display when pressing Main Power button. Can only repeat process after diconnecting power cord for Display and AVC unit for an hour or more. Was able to gain normal expected Display functionality once, over two day period in the course of following these steps, maintained normal TV operation. Following normal shut off, back with same problem.
  • 1 more comment
  • talog Dec 03, 2007
    Sharp has to know of this problem, I too have this problem on a unit 4-5 years old LC30HV4U and if there are this many looking for answers here how many more are out there? We need to let the right people know maybe even check with state consumers affairs department or BBB or maybe even Consumer Electronics there needs to be a recall on this.
  • Anonymous Jun 09, 2008
    My screen stays blue when I turn it on. The redlight will turn green than it turns red again? I need help.
  • Anonymous Mar 31, 2009
    followed the directions to turning on and off tv while holding buttons down - tv came on - enabled the write mode and then selected the second line down on the first menu 1-15 to have it restore. It went to ant A - turned tv off and now when we turn tv on the
    lights are green on both avc and tv, but screen is black - what can we try now? Also, to get it to turn on we still have to hold down all the buttons.
This is the problem with my LC-37HV4U. I plug in the AVC and the tv/monitor and I get both red power lights (not blinking) but no green lights, sound, or picture. I mean the tv screen stays black! It seems like their is no communication between the AVC and the monitor. I thought at least the screen would light up when the power light came on and being it has it's own power source. This tv is driving me nuts!! Can anyone please help?? Thank you.
Posted on Dec 03, 2009
Sharp aquos 32 I got same issue with the flashing red light, however when i remove the dvi-d connection cable from the avc system and connect it to my computer it works without any problems. I'm going to try a converter ive got which i use to connect my old crt tv with my computer ill need some cables to do that and then connect it to my freeview box and see if that works. If it doesn't the only solution i see is to throw away the avc system and use tv as a monitoras a computer monitor.I'll let you know if it worked in few days.
Posted on May 08, 2012
Same problem here 2003 LC-37HV4U, AVC unit just stopped working. Sharp wants nothing to do with it and won't help in anyway. You can buy a reman avc for $800.00. Best bet is to throw it out and buy a Sony.
Posted on Jan 13, 2008
    Problem Solver:
  • 6 Answers
OK. Here seems to be a solution that is working now. Unplug both the AVC and the panel (I used a power strip to make this easier by just turning off the strip and back on again). With the AC removed, press the "MAIN POWER" on. Next, press and hold the "VOL (--)" and "INPUT" at the same time. Finally, plug the AC power back in and the set should come on.
After it came on, mine was in a factory test mode. I had to enable the write mode (I think it writes to the PROM) and then selected the second line down on the first menu (1 of 15 ) to have it do the restore or something.
Finally, my set came up with OPC enabled to auto and it seems to have a sensor issue. At night, the monitor is unwatchable with such low light. So, I turned on a bright light near the monitor and set that to "Manual". so far, for two days and nights now it has been working again. I hope this helps. Good luck! -Brad
Posted on Aug 15, 2008
2 Suggested Answers
SOURCE:
bestdarngood
  • 3037 Answers
SOURCE: Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
Posted on Apr 26, 2008
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
thanks
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
I have just changed the ink in my printer and I have received an error message C18a0206. I can't locate this in my documentation. What is the problem?
PERFORM THE FOLLOWING STEPS:
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
1. Press and release the right arrow button until the display says “System Configuration Menu”.
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
May 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Our GE countertop microwave key pad does not work. The start and clear button does not work. owners mamual jes1651 . unit is 2 years old.
HI. Kindly, unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the error continues, the touch pad should be replaced asap.
Oct 19, 2009 | GE Microwave Ovens
C470
this is a fuser unit error code. reset code in following way.
1, turn off power. 2, hold down 0 & 8 keys. 3, turn on power still holding keys down until beep is heard. 4, enter 400 on numeric keypad. 5,press start button. 6,enter 0 on numeric keypad. 7,press enter icon on the main lcd display.8,cycle power
Oct 05, 2009 | Toshiba e-Studio 350 Copier
Need a power cord unit has no specs for amps/volts
Adaptec web site returns the following...
The replacement power supply must meet these specifications:
5 Volt DC Output with at least 2.5 Amperes capacity. The DC connector is configured with positive (+) on the internal or center lead and negative (-) on the external.
If you've found this reply to be a solution to your problem then please take time to rate this post. - Thanks.
Jun 28, 2009 | Adaptec AVC-2200 (avc-2210) Video Capture
Red light on display not green as usual no power
Hold down the "input" button and "volume -" button while the MAIN POWER BUTTON IS OFF. Then turn on the main power button while those are held down, the light on the tv & avc box will turn green. When it turns green, immediately let off the 2 buttons and press "volume +" button, then press the "Main Power" button. Next step is to repeat the process about 20-40 times & the TV WILL WORK!. I have read that this may have something to do with the energy star compliant commands that can changed through the serial port.
The above is from psxpirate25. Thanks!
I had to repeat the whole process a couple of times to get rid of the factory setup firmware mode. Do it 40 times, I would mess up the sequence a couple of times. Keep trying, it does work.
May 30, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
May 27, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sylvania 6842-PEM Flickering Problem
Something is breaking down. Possibly a specific ceramic capacitor on the main power pcb that has been troublesome. Usually there is just a loud pop and the screen goes dead. If the set is less than a year old it is still on parts warranty and the technician could just change circuit boards until the problem is gone.
Aug 30, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Sharp Aquos LC-37HV4U 37 in.  LCD HDTV Logo
1,199 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
