Question about Panasonic CT25G7 25" TV
No vertical deflection, only a thin horizontal line.
I would appreciate any help I can get for the following problem:
My television set is a Panasonic CTN 2766S and chassis APEDP204.
Problem: The top of the picture was a couple of inches short when the tv was first turned on. After five minutes or so, the picture filled out to normal and stayed that way.
It did this for about a year and then when the set was turned on, it only had a horizontal line in about the middle of the screen. It did not fill out no matter how long it was on.
I replaced the IC 451(LA7836-TV) “VERT OUT” and, also, replaced C553, 22UF/250V with a 32UF/250V capacitor because a service bulletin said the capacitor was drying out. That caused an increase in beam current resulting in a broken CRT neck.
When the tv was turned on. The raster filled out except for the top couple of inches. Adjusting the vertical size pot did not have any effect. IC 451 was getting hot in a short time. After 30 minutes the raster did not fill out, like it had done previously. I heard a sound like something was shorting out and the raster disappeared leaving only a horizontal line on the screen.
I made a check of IC 451 and found it was shorted.
Again, I would appreciate any help with this problem.
Wally
dede27@norwaymi.com
  • dede27 Feb 24, 2009
    Hi Benimur,
    I also want to thank you for your help, I appreciate it very much!
    I am assuming you have read my response to Shuttle as to why it took me so long to respond.
    I like the very helpful information you sent and I will certainly follow your advice when time permits me to do so.
    You are correct, for the most part, in the wiring of the componets !
    I had mentioned in my reply to Shuttle, I had been told I should have installed a LA 7836 kit. That it not only had the IC but also the resistors, capacitors and othe associated parts. Would you please the me what those parts are and values ?
    Again, I thank you very much for your help!
    Dede
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A few ideas you may want to consider/explore;
  • While it is true that capacitors do dry out, the values that you posted (22uF & 32uF) are relatively low for the pump/boost capacitor which is responsible for the "top of the picture was a couple of inches short". Normally this should be around 100uF connected between pin8 & pin 12 of LA7836;
  • agree that the Vertical IC LA7836 is busted hence the single line;
  • in most vertical designs, there would be a diode from pin7 that goes to pin12 that needs looking into for a leak;
  • pin7 is the Vert B+ ~ 24VDC while pin1 is secondary B+ 9 ~ 12 VDC. In some designs to accomplish this, there is a dropping resistor from pin 7 to pin 1 and sometimes a zener diode from pin1 to GND parallel with a filter capacitor;
  • pin11 is the vertical output that goes to the yoke. From the yoke some design uses another capacitor (about 1000uF) before going to the ground through a low resistor (~ 1 ohm);
  • above mentioned parts need to be checked out of ciruit preferable and special attention to possible leaks of the diode when testing in reverse bias mode.
Good luck and thank you for using FixYa.
Posted on Jan 30, 2009
2 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: No vertical deflection,only a thin horizontal line.
Hello dede27,
I suspect you have some background in electronics so I'll ask you some questions.
First, I know that you changed the output ic and a capacitor, the capacitor caused excessive beam current, that's bad, remember that beam current is dangerous because it can produce X-Rays. Remember to use the exact value of parts for X-Ray generating areas of the TV. So replace the C555 with the rated value by the manufacture.
As far as the vertical deflection problem it sounds like you may have a shorted vertical deflection coil (part of the yoke transformer). I would suggest testing the coil to see if it is shorted (A ring test will determine this). The Sencore LC102 has a ring test feature or you can lookup how to build a simple ring tester. In any event replace the IC and test the yoke transformer for shorts on the vertical winding.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
I have a thin line in my tv and i dont know what ic no.to replace?
The fault is a failure of the deflection circuit and since you have not specified whether it is a vertical or an horizontal line the section failed will be related to the position of the line.
If horzontal the vertical IC or the section related is faulty and if Vertical the horizontal section., Now this can be the deflection IC, teh deflection coils or even discrete components like capacitors or resisitors in this section which will require a signal trace with a voltage test before the absence of the sync pulses are confirmed and the section identified.
I request not to change the IC unless it is proved but you can solder the vertical IC or the section concerned -- if there is dry soldering.
Aug 25, 2011 | Toshiba 32A50 32" TV
STANDBY INDICATOR FLASHES FOUR TIMES.
this is a indiciation of loss of vertical deflection. is the a thin horizontal line? I have found feferences that capacitor c517 in the horizontal cuircit was shorted cause this .. cant be sure... also other components that might be at fault is the vertical ic 1509 transitor q1505 vertical buffer.
Oct 28, 2010 | Sony KP-43T70 43" Rear Projection...
Thin white horizontal line across otherwise black screen
CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. (On some sets, this is located on the CRT neck board and may be a jumper plug or other means of selecting service mode - not an actual switch.)
When moved to the 'service' position, it kills vertical deflection and video to the CRT. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection yoke or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection yoke on the CRT.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
Hope it works well...
May 28, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
When I power on my Mitsubishi CS-35313 tv, I only get a thin horizontal line across the center of the picture tube. What could be the problem?
There is a failure in the vertical deflection circuit. Typically there is a vertical output i.c. that provides the deflection vertically. The i.c. itself is a fairly common component to fail. There are some lower power circuits that feed this output device that also could be the problem. When the electron beam in the tube is not deflected vertically it "writes" only horizontally across the center of the screen thus resulting in a single trace. Be careful not to leave this at high brightness for any extended time as it can "burn in" that area of the screen. Unless you are a "techi" this is a job for a qualified technician. Troubleshooting would be in the vertical deflection section of the set. Most of the parts are not expensive in themselves, except for the deflection yoke which sits around the neck of the tube. The cost to repair would typically be the shop labor.
Nov 25, 2009 | Televison & Video
My television has no picture just one thin line in the center. Does anyone have any suggestions as to what is wrong?
You have a problem in vertical deviation in your television.It's need to be repaired by specialist.
Sep 28, 2009 | Symphonic ST419E TV
When we turn on the VS-5051 we hear a click, but get no power led, no sound, and only a thin white line across the screen. Can you tell us if this is worth fixing?
Hello: The problem with your television is that you have lost vertical deflection. The white line indicates you still have horizontal deflection, and the answer to your question. Is it worth fixing? My answer is yes This is a common problem that happens to all tube type televisions at some time in the life span of the television. The part that has failed is the vertical deflection IC and or the voltage to power the IC is missing, But the most common parts to fail in the vertical section are pump up capacitors on the output stages of the vertical signal. Parts for this problem are very cheap. IC around $12.00, Capaictors around .58 cents each, may require two of the (Capacitors that is). Highly recommend repairing this Set. Should not cost you more than $150 in labor and parts to repair this set.
Sep 25, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Hello dede27,
I hope this helps,
Thank you,
Shuttle83
Jan 30, 2009 | Panasonic CT25G7 25" TV
Toshiba 32A14 horizontal line
This symptom is characterized by a thin horizontal line in the middle of the screen. This symptom is caused by the absence of the deflection sawtooth current in the horizontal deflection coil.
The trouble is easily isolated by a continuity test and by checking the most likely defective components such as A)open vertical linearity compensation transformer, B) open capacitor and C) open horizontal deflection coil.
Be sure to decrease the brightness first before trouble-shooting if the line is very bright,as it burn the phosphor screen..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 19, 2008 | Toshiba 32A33 32" TV
Vertical problem,
chek tje vertical deflection yoke winding and the socket. readjust the vertical height control.hope this will help.
Feb 05, 2008 | Samsung TXM3096WHF 30" TV
GE 35GT168
If you indeed have a line down the center of the screen that means the horizontal output transistor is working as it produces high voltage as well. The rectifiers are working otherwise you would have no power or sound. What you need to look at is either the horizontal windings of the deflection yoke are open or you have a open return from the yoke to the horitontal output stage.
May 06, 2007 | GE 35GT740 35" TV
Panasonic CT25G7 25" TV Logo
276 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
