Question about Jensen VM9510 Car DVD Player
Xbox 360 red lights
How do i fix it?
The Issue is with the heat sink inside the Xbox 360 when the console gets hot after playing hours of online halo tournaments the heat actually get so hot that the sauder from the pci chips, and the mother board get loos and separate. The way to fix this is take it apart and have it re saudered, or send it back to microsoft, if you do either you need to get a powerflo fan and put it on the back of your console I have had the same 360 for about 2 years and I have never seen my console get hot because the fan pulls all the hot air out and sucks the cooler air in. I hope I could help
Shawn Contreras
Posted on Feb 03, 2009
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
Red ring
hi there,
your xbox 360 need service open it and remove all dust around the fan and prosseser every thing fine again.
Jul 11, 2010 | Microsoft Xbox 360 Console
One red light on xbox 360
In most cases If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages.
HERE IS THE RED LIGHT REPAIR MANUAL: http://docs.google.com/viewer?url=http%3A%2F%2Fpdftown.com%2Fpdf-ebook%2FXBOX%2520360%2520Repair.pdf
Oct 19, 2009 | Microsoft Xbox 360 Console
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
Sep 20, 2009 | Microsoft Xbox 360 Console
Xbox 360 repair in mumbai :- 9819767710/9867635653 ?
HELLO ALL GOOD NEWS FRIST TIME IN INDIA
XBOX 360 3 RED LIGHT ? NO PROBLE CALL ME NOW
WE ARE PROFESSIONAL ALL TYPE OF VIDEO GAMES REPAIRING. NOW WE HAVE NEW SOLUTION FOR XBOX 360 3 RED LIGHT FIX. WE CAN FIX 3 RED LIGHT PROBLEM WITH GUARANTIED.
NOW WE CAN PROMISS U FOR YOUR XBOX 360 VERY EASY NEVER BECOME 3 RED LIGHT PROBLEM. NOW WE HAVE VERY GOOD SOLUTION FOR 3 RED LIGHT.
IF YOU WANT BEST SERVICE AND SPECIALIST REPAIRER FOR YOUR ALL TYPE OF VIDEO GAMES.
PLS FEEL FREE CONTACT US
MAHBOOB ALAM & SERAJ AHMAD
MOB : +919867244969
EMAIL : mahboobidrishi@hotmail.com
Website : http://sonyservice.en.china.cn/
Jan 23, 2009 | Microsoft Xbox 360 Console
Xbobx 360 3 red lights
3 Red lights problem is a drawback of Microsoft Xbox 360
Check out the blog post at http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/ to know more information on fixing your xbox
Jan 07, 2009 | Microsoft Xbox 360 Console
3 red lights
it means you have a lose wire
Jan 04, 2009 | Microsoft Xbox 360 Console
Jensen VM9510 Car DVD Player Logo
37 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
