Question about Lexmark X9350 All-In-One InkJet Printer
Need to Override Ink Level - for High Yield Ink Cartridge
I have started buying the High Yield Ink Cartridges for my Lexmark X9350. These are store bought and not refilled cartridges. The problem is that is shows my ink is out and will not allow me to print documents from my computer, but I can force it to make a copy and the ink looks good.
Note: I have unplug and restarted numerous times.
Does anyone know how to adjust the printer for high yield ink cartridges?
  • valuikas Jan 31, 2009
    Yes, we have reinstalled, cleaned, realigned heads,...everything you can do under the maintence menu. I guess, I will not waste my money on the 44XL & 43XL ink.
  • 340 Answers
have you tryed to remove the cartridges, en reinstalle them again? - you then have to run the ajust job...
/Teis
Posted on Jan 30, 2009
Lexmark S305 won't authenticate ink non brand
Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark. Also, when you use off-brand inks and cartridges, there is no way for Lexmark to be sure that materials and engineering choices used by a third party will not result in poor print quality or damage to your printer.
I highly recommend that you return your third-party cartridge if you still can get a refund and purchase genuine Lexmark cartridges instead.
Here's a tip to save on ink: A 100 "standard yield" cartridge for your model has a low sales price, but contains less ink. Your best value is a 100XL "high yield" cartridge. These have a higher sticker price, but contain almost 3 times as much ink as their standard yield cousins.
For the most optimal output experience with your model, I recommends that you update your printer firmware. The firmware helps ensure that you receive the highest yields of ink available from the cartridges, which offers the greatest value and means fewer necessary cartridge replacements. Please visit the Lexmark website to download and install the Lexmark S300 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Dec 30, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Poor print quality
Make sure you are using genuine Lexmark cartridges. Lexmark products work best with original supplies. Lexmark does not recommend the use of refilled, re-manufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Check your cartridge ink levels. From the printer operator panel, go to Maintenance > View Ink Levels. Replace the cartridge that has low ink level. If your ink levels are still substantial for printing and you are using genuine Lexmark supplies, please contact Lexmark Technical Support Center for further assistance.
Dec 28, 2011 | Lexmark X9350 All-In-One InkJet Printer
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
What size ink can i use
You can use the 32 Black / 33 Color Standard yield cartridges or the 34 Black / 35 Color High yield cartridges on the Lexmark X5470 printer. Lexmark cartridges are available in most large office supply stores and online at lexmark.com.
Aug 11, 2011 | Lexmark X5470 All-In-One InkJet Printer
Got my Lexmark z2420 printer ink refilled at Office Max, but it is still showing as empty. Anyway to by-pass this and get it working?
You cannot refill lexmark ink cartridges successfully suggest you buy the original as you are not easily going to find generics good luck try and buy the high yield cartridge at least 200-300 pages extra depending on the model
Nov 22, 2010 | Lexmark Z2420 Printer
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Lexmark x9350 printer gives error message #1203
I logged into Lexmark's web site and checked their printer support page. It said that if you get error message 1203 your ink cartridge has leaked fluid. In order to find the right cartridge, do the following. Remove both ink cartridges, put in one, turn off the printer, turn it back on and if you get the message 1203 that's the cartridge with the problem. I did not get that message. I turned off the printer, put in the other cartridge, and turned it back on. Sure enough, I got the 1203 message again. (I had cleaned the wrong cartridge before). I removed the leaky cartridge, cleaneded it (making sure I did not leave any residue) and put it back in the printer. It worked!
Jun 13, 2009 | Lexmark X9350 All-In-One InkJet Printer
Please send me e-mail with answer. Need to know what cartdriges black and color for my Lexmark X5495 Thanks
The Black cartridge # is Lexmark # 28A (18C1528)
The Color cartridge # is Lexmark # 29A (18C1529)
The High-Yield (more ink in cartridge) Black cartridge # is Lexmark # 34 (18C0034)
The High-Yield Color cartridge # is Lexmark # 35 (18C0035)
The Photo Color cartridge # is Lexmark # 31 (18C0031)
Sep 18, 2008 | Lexmark Office Equipment & Supplies
What kind of cartdrige,black and color for my printer Lexmark X5495. Thanks
You need a Lexmark 28 Black and 29 Color. You can get these easily at any Staples store or just try this link:   http://www.staples.com/office/supplies/c29_Inkjet-Laser-Printer-Cartridge-Ink-Toner-Finder-Lexmark-X5495_57173_Lexmark_Brands_27176_Business_Supplies_12328_a400_10051_true
Use of High yield Cartridges in Canon Pixma 150
have u tried to remove the cartridge again, proably some contact problem
May 27, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Lexmark X9350 All-In-One InkJet Printer Logo
917 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
