Question about Panasonic CT25G7 25" TV
No vertical deflection,only a thin horizontal line.
I would appreciate any help I can get for the following problem:
My television set is a Panasonic CTN 2766S and chassis APEDP204.
Problem: The top of the picture was a couple of inches short when the tv was first turned on. After five minutes or so, the picture filled out to normal and stayed that way.
It did this for about a year and then when the set was turned on, it only had a horizontal line in about the middle of the screen. It did not fill out no matter how long it was on.
I replaced the IC 451(LA7836-TV) “VERT OUT” and, also, replaced C553, 22UF/250V with a 32UF/250V capacitor because a service bulletin said the capacitor was drying out. That caused an increase in beam current resulting in a broken CRT neck.
When the tv was turned on. The raster filled out except for the top couple of inches. Adjusting the vertical size pot did not have any effect. IC 451 was getting hot in a short time. After 30 minutes the raster did not fill out, like it had done previously. I heard a sound like something was shorting out and the raster disappeared leaving only a horizontal line on the screen.
I made a check of IC 451 and found it was shorted.
Again, I would appreciate any help with this problem.
Wally
dede27@norwaymi.com
  • dede27 Feb 22, 2009
    Hi Shuttle,
    Thank you for your help! Sorry it took so long to answer. I had trouble with my PC and then the password. I contacted Fixya and they gave me a new one.
    After reading your comments, I went back and looked at the Service Bulletin. It said to "Replace C553(P/N ECEA2EU220) and add a 10UF/250V electrolytic capacitor (PN ECEA2EU100) across it on the underside of the board."
    I don't know what I was thinking. I figured the two capacitors were in parallel so I put in one 32UF/250V capacitor. I did not realize at the time, C553 was a special capacitor and that's why the bulletin had a special installation procedure.
    Do you think this had something to do with burning out the IC?
    Recently I was told I should have put in an IC 451 Vertical Output kit and it not only had the IC but also the associated capacitors, resistors, etc.
    Do you know what those components are? If so, would you please tell me what they are or where I could get the kit?
    I have an extra IC 441 Vertical Output. I do not want to put it in until I have hopes of finding out why the other one burned out.
    Regarding the vertical deflection coil: If it were shorted, one would think the picture would have been distorted after I had put in the new parts. When I started the TV it had a nice picture. There was no distortion at all.
    Again,thank you,
    dede27
  • dede27 Mar 15, 2009
    Again, thank you Shuttle!
    I did not know there is such a thing as "auto correcting circuits". I'm indebted to you for your time and expert help.
    Did you read my reply to the other man and, if so, what are your thoughts on my reply to his post? I'd especially like to know if there is such a Vertical Deflection kit and where would I get it ?
    I had been told the kit contains all the components that could go bad. Do you know what they are?
    Many thanks for your much appreciated help!
    dede27
    Genius:
  • 1,139 Answers
Hello dede27,
I suspect you have some background in electronics so I'll ask you some questions.
First, I know that you changed the output ic and a capacitor, the capacitor caused excessive beam current, that's bad, remember that beam current is dangerous because it can produce X-Rays. Remember to use the exact value of parts for X-Ray generating areas of the TV. So replace the C555 with the rated value by the manufacture.
As far as the vertical deflection problem it sounds like you may have a shorted vertical deflection coil (part of the yoke transformer). I would suggest testing the coil to see if it is shorted (A ring test will determine this). The Sencore LC102 has a ring test feature or you can lookup how to build a simple ring tester. In any event replace the IC and test the yoke transformer for shorts on the vertical winding.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 30, 2009
  • Henry McKelvey
    Henry McKelvey Feb 25, 2009
    Hello dede27,
    In reply to your statement:
    This is not necessarily true or false, because it depends is you TV has auto correcting circuits as some TV do, If the coil was to develop a short which causes excessive current to flow and a lowering of the deflection signal, the circuit would auto correct and make the picture appear normal until the problem was so bad that the auto correction circuit could not make up for the distortion. You have indicated in your first statement that the picture had some distortion:
    "Problem: The top of the picture was a couple of inches short when the tv was first turned on. After five minutes or so, the picture filled out to normal and stayed that way."
    This statement lead me to believe that auto correction was being done in this case, or a component was developing a charge as it played and warmed up.
    I hope that I did not mis-lead you in your efforts, I just wanted to cover as may possiblities as I could with the least amount of technical jargon.
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc...
  • Henry McKelvey
    Henry McKelvey Mar 16, 2009
    Hello dede27,
    Yes many electronics parts stores now put together such kits for well known problems. I have always first tried to do troubleshooting and then parts replacement checking the waveforms and signal levels before concluding a repair job, These kits are helpful because they contain "most" of the parts that need replacing, but nothing beats a good and complete troubleshooting job on electronic devices.
    Thank you,
    Shuttle83
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
STANDBY INDICATOR FLASHES FOUR TIMES.
this is a indiciation of loss of vertical deflection. is the a thin horizontal line? I have found feferences that capacitor c517 in the horizontal cuircit was shorted cause this .. cant be sure... also other components that might be at fault is the vertical ic 1509 transitor q1505 vertical buffer.
Oct 28, 2010 | Sony KP-43T70 43" Rear Projection...
Thin white horizontal line across otherwise black screen
CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. (On some sets, this is located on the CRT neck board and may be a jumper plug or other means of selecting service mode - not an actual switch.)
When moved to the 'service' position, it kills vertical deflection and video to the CRT. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection yoke or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection yoke on the CRT.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
Hope it works well...
May 28, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Vertical Deflection problem on Panasonic TC29V10A
replace the vertical Ic and it probably failed because of the two Electrolytic Capacitors so check and replace if necessary. Not for a beginner but if you are good with a soldering iron and ****** it is possible.
Oct 08, 2008 | Panasonic Televison & Video
Toshiba 32A14 horizontal line
This symptom is characterized by a thin horizontal line in the middle of the screen. This symptom is caused by the absence of the deflection sawtooth current in the horizontal deflection coil.
The trouble is easily isolated by a continuity test and by checking the most likely defective components such as A)open vertical linearity compensation transformer, B) open capacitor and C) open horizontal deflection coil.
Be sure to decrease the brightness first before trouble-shooting if the line is very bright,as it burn the phosphor screen..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 19, 2008 | Toshiba 32A33 32" TV
Vertical problem,
chek tje vertical deflection yoke winding and the socket. readjust the vertical height control.hope this will help.
Feb 05, 2008 | Samsung TXM3096WHF 30" TV
Green horizontal deflection
Change both STK convergence IC's for reliability. They amplify/control both horiz and vertical. re-align after replacement.Locate them on the largest heat sink in your set!
Sep 26, 2007 | Panasonic PT-53WX42 53" Rear Projection...
GE 35GT168
If you indeed have a line down the center of the screen that means the horizontal output transistor is working as it produces high voltage as well. The rectifiers are working otherwise you would have no power or sound. What you need to look at is either the horizontal windings of the deflection yoke are open or you have a open return from the yoke to the horitontal output stage.
May 06, 2007 | GE 35GT740 35" TV
Panasonic CT25G7 25" TV Logo
651 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
