Question about Magic Chef CGR1110 Gas Kitchen Range
Magic Chef Gas Range
I cannot get my stove top to light. The gas is on, the oven lights just not the stove top
  • 10 more comments
  • Anonymous Feb 15, 2008
    Gas Range Oven is OK
    One of 4 Burners WILL NOT light...
    Two move give a popping noise after they are turned off.
    Can Burner lines be REPLACED ??/
  • tenswamp Mar 31, 2008
    cook top gas range two burners will ignite with spark two will sometimes work but more than often they will not have a spark. gas is coming from burner but no spark.
  • mcaceres1 Sep 06, 2008
    I can't get my stove top to light. oven light is on, gas is on but i don't get that tick- tick to light. what is the problem? I try unpluging the stove and pluging back on move the wires and no solution. please help!!!!
  • NICK1ANITA49 Mar 25, 2009
    BURNERS PRODUCE A SPARK TO IGNITE THE GAS
    MY BURNERS WILL NOT PRODUCE A SPART - ITS SNAPPIONG TRING TO START THJE SPARK
  • jfabsal May 11, 2010
    my pilot light is on constant and one flame is higher than the other causing black smuck under stove lid creating a smell and I have to contantly clean under the lid. how can I stop this pattern?
  • Anonymous Mar 13, 2014
    Tap pan gas stove top won't light
  • Anonymous Mar 14, 2014
    cornufe 44 dual fuel range . the oven won't turn on and the stove top isn't clicking to light
  • Anonymous Mar 15, 2014
    magic chef stove oven won't light but thermal copling will
  • Anonymous Mar 23, 2014
    Just want to know how to start the process - I press button on the top of the stove but nothing happens - light goes on by the button but then goes off and nothing happens.
  • Anonymous Mar 26, 2014
    this unit will not up after a 500 mile trip. It is not getting 12 volt power as a light over the stove is not lighting up either. The remaining 12 volt lights in the camper ar working. The gas range is working. The control panel does not light up after pushing controls.
  • Anonymous Mar 30, 2014
    replace thermostate
  • 20 Answers
Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
Posted on Aug 01, 2007
SOURCE:
How does the top open is it lifting from front of stove top or threar of stove top
call a repairman being a GAS unit I will not recommend DIY the explode if not done properly SORRY
Feb 03, 2016 | Magic Chef 31000 Gas Kitchen Range
Magic chef gas range top burners will not stay light
This problem is almost always due to a defective gas valve. If you decide to replace the part yourself remember safety 1st, turn off the gas and disconnect power to the range.
Nov 16, 2011 | Magic Chef Kitchen Ranges
I have an early 70's Magic Chef series VI oven/stove. The stove works fine. The oven takes about 30 minutes to light. When oven knob is turned pilot works fine. There is no gas odor before the oven lights.
My model is a UA119A-2W and I cannot find a place to light the oven pilot. Nor can I find a copy of the owner's manual anywhere online. Any suggestions would be appreciated.
Apr 05, 2010 | Magic Chef 31000 Gas Kitchen Range
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
I have a 1948 Magic chef gas oven.Model # 8620. The gas was turned off at my home and the pilot light on the oven went out. The gas is now on and I need to relight the pilot light. I am not sure on the ove...
You did say 1948, as in 60 year old range?
Well, gas ranges did not have fancy safety valves or things like that back then. Most likely when you turn on the gas, a small amount of gas begins escaping at the pilot orifice. Then use a long handled lighter to put a flame there. Pilot should light right away.
Oct 11, 2008 | Magic Chef Kitchen Ranges
Oven not working (lighting) on magic chef stove top/oven
look at the burners in the oven,they usually go bad where they hook to the unit,it will look like a peice is missing.if this is not the case, a wire is loose in your breaker and you're running on 110 instead of 220
Sep 04, 2008 | Magic Chef 31203 Gas Kitchen Range
Pilot lights
you need to plug the oven in; pull it out and you should locate the pwr cord or you may already have it plugged in and have a breaker turned off or a gfi tripped
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 19, 2008 | Magic Chef Kitchen Ranges
Magic Chef CGR1110 Gas Kitchen Range Logo
962 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
