Question about Durabrand DB1200 CD Player
Included wiring lost
After i pulled the radio out of my dad car i lost the the wires that came with it.
does anyone know where i can order a new set?
  • 11,896 Answers
ALCO is the manufacturer of the Durabrand name. For televisions and other select items, FUNAI is the manufacturer. WHAT ABOUT LENOXX? Well, Lennox is a trading company that offers the warranties and manuals for the Durabrand name, just as ORION offers the warranties for the television and computer products
Posted on Jan 30, 2009
    President:
  • 1,990 Answers
You can get Replacement Wiring Harnesses from the Durabrand Website under Parts. Or Check out Crutchfield.com and see if they have a Replacement. Go to the Customer Service Part. Please Rate My Response! Thanks!
1994 honda accord radio wont save settings.
If you have a multimeter or test light, try to find a wire that still has 12v when the key is off. Connect that wire to the yellow wire of the radio. The yellow wire has to have constant voltage going to it to maintain the memory.
Feb 11, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
Hello I just bought a new stereo for my mitsubishi galant 2002 but i need to know the wiring diagram in order to make the installation if anyone can help thanks
Wiring adapters are available for nearly every make of vehicle, which allows you to plug right in to the original radio connectors. They come with wiring diagrams, and are nearly idiot proof. They cost usually about 10 to 15 dollars, and are available just about anywhere that sells car stereos. This also allows you to reinstall the factory radio when it comes time to sell the car and you want to keep your stereo.
Sep 05, 2011 | 2002 Mitsubishi Galant
I have a used unit, need instructions on how to hook it up to a caddy 1995 factory am/fm radio
Are we talking a new deck/stereo or new speakers/subs?
A new deck will require a wiring harness (cheap at walmart or local auto place) and this will come with a set of directions and wiring diagram for your make/model vehicle.
Subs/Speakers can be wired into a stock AM/FM radio (though I have no idea why anyone would want to do this) fairly simply, The wiring diagram will be printed on one side of your stock radio letting you know where to attach the 12v constant, the remote wire, and the speaker wires.
May 09, 2011 | Car Audio & Video
How do you replace the radio and insert a cd player?
Hi, pull the trim plate off the dash around the radio. The trim may go all around the instrument panel. With the trim plate off, you can see the factory radio screws. Take the screws out, pull the radio out and remove the connectors, including the antenna wire.
You will need an adapter to fit the aftermarket radio snugly into the dash. They sell these wherever they sell aftermarket radios. I recommend you also buy the cable adapter. If you don't, at least buy the antenna adapter of you will no be able to plug your antenna into the new CD player.
Follow the instructions on putting the adapter together--it's made for a lot of different cars. You need it to screw into your dash where the screws came out.
If you buy the wire adapter, follow the directions that come with it. I recommend you solder the wires, but you can use those crimp connectors if you don't have soldering equipment.
If you don't buy the adapter cable, use the factory wire colors below to match up the aftermarket wires to your factory wires. Wrap any solder connections with electrical tape and carefully plug everything back in, including the antenna adapter and antenna cable. With the adapter plate attached to the new player, carefully push the wiring aside to get the player into the slot and then screw it in. check the system for proper operation and then replace the trim panel.
Enjoy your CDs, and let me know if you have any questions.
2002 Chevrolet Silverado C1500 Radio Wiring Instructions
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2011 | 2002 Chevrolet Silverado 1500
Stereo Wiring Colours
2006 Ford Focus Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
Jul 11, 2010 | 2006 Ford Focus
I need a radio code for my 98 ford mondeo i have lost the keys to remove the radio to retrieve my serial no does anyone know how i can get a code without me buying a new set of keys?
Try  2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end)  or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
Nov 28, 2009 | Car Audio & Video
Subs on stock radio
chev stock radio does not have extra plug in for sub. to run your sub, im assumed you also going to run an amp to it also. there are no addition plug in in the back, but that does not stop anyone if you know how to rig things. i would not recommend rig wires on your 2007. I would install a new radio before rigging that car; than add a sub. keep in mind most of GM radios come with stock amp built into the radio itself. If you cut the wires from the radio and wire it to your sub amp you will get nothing but distorted sound. anything sound goes to any amp need to be pre-amp in order to work properly. hope that help some
May 16, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
Yellow Wire has no power
Your stock radio should have had a wire that does this. It may not be yellow so look up the wiring diagrams for your car. If you can't find it by doing that, then look up a diagram of your use box. Sometimes there's a diagram on the back of the fuse panel cover or somewhere around there that tells you what fuses are from what. You can then run a new wire if you have to.
Jan 08, 2009 | Car Audio & Video
Sansa clip v 01.01.11a
this is a problem but i know how to fix this
the sansa clip wire is the same as a motorola phone wire
you can easily by one from a rogers store
i know this because i lost my wire and ended up using my dad's.
hope this helps :)
Jul 09, 2008 | SanDisk Sansa Clip MP3 Player
Need one set of speaker wires.
If the wires have just bare ends plugged into spring-loaded contacts then you can get some twin lead from radio shack or walmart. Just make sure you match the colors from the stereo to the speakers
otherwise you might not get real stereo or surround.
Jun 02, 2008 | Sony DAV-S300 System
Durabrand DB1200 CD Player Logo
303 people viewed this question
Top Durabrand Car Audio & Video Experts
matt martin
matt martin
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
