Question about Zanussi ZX99 / 5 Bottom Freezer Refrigerator
Trips Electric every 7-8 hours
I have a Zanussi ZX99/5SI that trips the electric in the house every 7-8 hours. I suspect that the defrost element is faulty (earthing) is there any way I can prove this ?
  • 700 Answers
You actually have in a way since the timer on the defrost goes into every 8 hours.
Posted on Feb 01, 2009
Zannussi zdc37100w trips the fuses in my house when i try to put it going
the heating element is probably shorting out to the heater case and blowing the breaker or the dryer motors bad and drawing too much current
Aug 07, 2011 | Zanussi ZDC37100W Electric Dryer
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
Cooker oven not working - replaced bulb. Hot plates still work.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Jan 07, 2011 | Zanussi ZCE611X Electric Kitchen Range
When you turn on the drier it trips the electricty. there is power in to the power switch but when you turn the dial it trips the fuse box. the model is TC7103W
an electrical earth leakage will cause the trip. possibly the the heating element. but the motor or wiring fault can do it. you could try disconnecting the heater if the electric stays on. then change the element.
Jul 22, 2010 | Zanussi Dryers
ZANUSSI Oven E025
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
May 15, 2010 | Zanussi ZBF360 Electric Single Oven
I have a zanussi zce7680 and the fan works but no heat any ideas
heatman101
May 05, 2010 | Zanussi ZCE7680 Electric Kitchen Range
Fan not heating
Mar 12, 2010 | Zanussi ZBQ665 Electric Single Oven
Zanussi tc 7102w and when i turn it on it trips power
element short to ground.. coins hair pins clean try again
Aug 17, 2009 | Zanussi TC7102W Electric Dryer
Oven keeps tripping the electrics
I would suspect that the fan oven element is faulty. what I think is happening , is as the element gets hotter, the insulation is breaking down and causing the trip to operate, it is quite a common problem
You will need to fit a new element.
If it is a fan assisisted oven you will find the element behind a removable cover at the rear of the oven compartment..
Plz rate my solution.
Thankyou.
Jan 06, 2009 | Zanussi ZBF360 Electric Single Oven
Zanussi frostfre fridgefreezer r600a
if a frost free type and happens only now and again, suspect defrost element short to earth
Mar 20, 2007 | Zanussi ZEBF277W Bottom Freezer...
Zanussi ZX99 / 5 Bottom Freezer Refrigerator Logo
136 people viewed this question
Top Zanussi Refrigerators Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
