Question about Goodman GMS90703BXA Heater
Thermostat at 70, shuts off at 62. stays only 1/2 hour at at time
The Thermostat is new, honeywell, dial style. All was working until recently. Now we have to turn the thermostat down to below showing temp, (62) listen for click. then turn it back up until it clicks again. The furnace goes on after 2 or 3 tries and only stays on for about 20-30 minutes. Goes for hours before it will try to restart then it fails several times. LED like does not send a specific signal, it just keeps flashing on and off.
  • rhickey2005 Jan 31, 2009
    I know the LED light blinks with a cadence, that's why I wrote that it just kept blinking on and off, I stopped counting after 19. Later on I took off the cover and checked again. I got a sequence of 4 blinks.
    President:
  • 1,214 Answers
What LED are you talking about that keeps flashing?
If it's the LED on the controller board in the furnace, they blink with a cadence that you need to watch. There will be a data sheet somewhere on the furnace that will tell you what the cadence (flash cadence) is.
Replay back and I can help you more.
Posted on Jan 30, 2009
  • Mark Egan Jan 31, 2009
    OK. Now we're getting somewhere.
    Look on the your panel for the unit or control box and tell me what the 4 blink code is.
    I will be in and out today, but I will get back to you.
Why does my Honeywell thermostat state temporarily set at 68 degrees? A few days later, it will be set at 62 degrees without anyone touching the thermostat?
It's a programmable thermostat. When you change the temperature, it will say temporary until the next programmed schedule starts or a set amount of time. You will have to program the thermostat to the correct temp settings you wish to have, or you can push "HOLD" after changing the temp to make it stay at that set point. Hope this helps!
Nov 19, 2016 | Heating & Cooling
Dip switch settings rthl2310
Check for cold air inside the wall behind the thermostat, a cold wall, and area that is getting hot or cold air blowing on the thermostat. Last, the heater may not be compatible with some digital thermostats. Honeywell Customer Care toll-free at 1-800-468-1502.
Aug 29, 2014 | Honeywell Programmable Thermostat Heater
Heat Pump will not shut off
flow switch timer in the unit. its a part on the pcm board. tell the pump to stay on for 10min after heat up. and does other times as well depending on setup... its not really a switch its a chip but it works as a switch.
Mar 08, 2014 | Honeywell Programmable Thermostat Heater
Thermostat set at 74, but air conditioner won't turnoff
Need to reset the lever sensitivitie( behind the cover) to a lower setting.
Jul 22, 2009 | Honeywell Heat/Cool Thermostat
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
My Honeywell TH4210D1005 Thermostat will not respond
well with 62 outside temp and then maybe a little solar gain and body heat you very well could be 5 degrees warmer then outside
Apr 06, 2009 | Honeywell TH4210D1005 Heater
Have gas furnace and this winter,began having
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
However - the problem is probably not with your thermostat but with your furnace. It is most likely a dirty flame sensor - a maintenance issue. If you have not had your furnace serviced recently (more than 1 year) that is where you should start. Modern furnaces require regular maintenance.
Please rate my answer!
Feb 28, 2009 | Honeywell Electronic Programmable...
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Need help with rth230b
AFTER ST UP. HOW DO YOU PUT IT IN PROGRAM MODE?
Jan 23, 2008 | Honeywell Programmable Thermostat Heater
Loss of temperature control
Is the heater staying on all the time? Most likely cause of themostat trouble is the sensor. Try to find it and measure its resistance at different temps to verify the trouble.
Dec 31, 2007 | Honeywell CT3200 5-2 Day Electronic...
Goodman GMS90703BXA Heater Logo
116 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
