Question about Acer Aspire 5315 Notebook
Phazing when i connect computer to mixer + amp i get really bad interferance from laptop coming over load speakers ,could i be missing a diver to stop this if so which one would it be.
  • Anonymous Jan 30, 2009
    i am problem my acer aspire one; the sound not found,,,end panel key.control..
    help
  • lanzarotepau Jan 30, 2009
    i am using the head phone jack to connect to mixer and the phazing interferance is still coming though from the computer
  • 114 Answers
You need to adjust the volume on the computer down or use the headphone jack instead of a speaker output (if it has one).
Posted on Jan 30, 2009
  • BillW50 Jan 30, 2009
    Did you also turn the volume down too? If you can't find any satisfactory solution, what many professions do is to use an external sound card. Either USB, PCMCIA (PC Card), or ExpressCard. They do this because most built in sound cards are too noisy for them to use.
How to connect Behringer qx1200 mixer with pc and pc/speaker? I tried all solutions but i didnt' get any sound. Earphones works great
the mixer connects to the pc via usb or analogue i/p's
the mixer does not connect to the pc speaker
this has to be done with the software you're running on your computer
the easiest way is..plug the headphone o/p into any amplifier line i/p
( amp and speakers or powered monitors ) and forget about the pc speaker ..they're sh!te period ..or you can plug the headphone
o/p into the mixer then the mixer into an amp but this is more complicated and you will need to read up on it
but do yourself a favour and get some small multimedia speakers
similar to these for starters http://www.ebay.co.uk/itm/GENIUS-BLACK-MULTIMEDIA-STEREO-SPEAKERS-SYSTEM-for-LAPTOP-DESKTOP-PC-COMPUTER-UK-/250929417549?pt=UK_Computing_Speakers&hash=item3a6c8f0d4d
May 28, 2014 | Behringer Audio Players & Recorders
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
Dec 06, 2013 | Yamaha Music
Hope you guys can help... I have a laptop Karaoke system. I connect from laptop to 6 channel mixer to speakers. I use a stereo phono to RCA from laptop to mixer. I am experiencing a buzz coming through...
Yep! Get a decent audio interface that attaches to the PC with a USB connection and uses BALANCED lines to your mixer. I use a UA-25EX Roland/cakewalk as an example. (about $200 and there are cheaper units such as M-Audio Fast Track MKII ) Note these interfaces BOTH record and playback with two channels for stereo.
Essentially the audio board that is in PC's and Laptops are too near the switching noise of the processor and some of that is just bound to get into the audio lines as they don't even have balanced audio lines from the computers. Make sure you use either TRS or XLR balanced cables from whatever interface you get. Also connect ALL interconnected equipment to the same power source or receptacle. You can try to reduce the buzz with the mixer EQ's with what you have, but that sacrifices audio quality.
Mar 30, 2011 | AMP Speakers Pro Karaoke System
Hey, i bought a new pair of samson auro D415 speakers and i connect them in parallel because one of my main mixer outputs ain't working.but even if al my signal gains and fader levels are low,the peak...
Check only one active speaker at the mixer output and report the results.
Connect only one of the audio inputs from the power amp at the mixer output (and the passive speakers at the output) and report the results.
Sometimes (in parallel connections) there are interferences from the volume controls.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 30, 2011 | Samson Auro D415 - 2-Way Active Speaker...
How do i go about connecting the alesis monitor one mk2's to my my laptop? i do not have an amp and there are no cables or connectors with the speakers when they arrive
You can without an amp in between. They are non-powered speakers and need an amp to drive them. If you connect your laptop to a mixer, mixer to an amp, then amp to speakers THEN they will work.
Feb 19, 2011 | Alesis Monitor One Mk2 Speaker
Sounds really bad through the speakers. No lights
This has the earmarks of a failed power adapter. If the voltage is low, everything will saturate. WARNING: You could do damage to the electronics if you try to drive high levels through the unit to compensate for low output from unit.
Check the voltage from your adapter. Check it UNDER LOAD as it may collapse when connected to the unit.
Mar 27, 2010 | Vestax Pmc 280 DJ Mixer
Electrical interference on a DELL laptop.
Try a ground lift on the audio desk Im guessin it phase issue
ground lift is a small grey or orange 2 prong mail and 3 prong female any hardware store will have them...FYI
May 14, 2009 | Peavey 32fx USB 32 Channel Mixer
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
Acer Aspire 5315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
