Question about GE Wireless Optical Mouse
97990 Rev. 4
My relatively new mouse stopped working. I've tried everything...changing batteries, cleaning, checking USB port...nothing works. The little upper right light goes off about 5 seconds after I change batteries, etc. Can you help me. I'm ready to toss it. Thank you.
  • nolagirl_69 May 09, 2009
    I have a a ge wireless optical mouse 97990 and it just stopped working. I changed the batteries and everything the little light blinks on the receiver part and everything it just wont move. I need help someone please. Is there a reset button on it and where is it located?
  • Weldon Dube'
    Weldon Dube' May 11, 2010
    Normal
    0
    Turn the mouse over and find the small
    rest/connect button
    on the bottom of the mouse and press it.
    This should connect the mouse to the receiver and work properly.
    If not, try pressing the receiver button and then press the button on
    the mouse
    . This should be done whenever you change batteries or
    glitch
    Hope this helps you. Bud
    President:
  • 8,637 Answers
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Posted on Mar 25, 2009
  • Weldon Dube'
    Weldon Dube' Apr 16, 2009
    Normal
    0
    If the MOUSE isn’t working, push the small
    RESET/CONNECT button
    on the back of the mouse to connect to the receiver.
    Then it should work okay.
    Hope this helps. Bud
My cursor is stuck in the middle of my screen on my computer, my mouse is wireless so i tried changing the batteries and using every USB port and still nothing. I then got a wired mouse and tried that in...
Sounds like USB stopped working(maybe driver related). Try booting into safe mode by pressing f8 at startup before the logo screen for windows appears. If it is working in safe mode then it is not hardware but rather driver related. This also sounds like an older computer that might have a ps2 mouse port. If you have an old ps2 mouse you can try that.
Aug 14, 2017 | Microsoft Comfort Optical Mouse 3000...
Wireless mouse stopped working. It's new. I've tried everything. It was working this morning.
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
hope this helps
Jul 26, 2011 | Computers & Internet
I have #97990. The batteries are done within a half of a day, even when I switch it off
Replace the rechargeable batteries. Even rechargeable batteries only can be recharged so many times and then they will not hold a good charge.
Oct 29, 2010 | GE Wireless Optical Mouse
GE Wireless "Malfunction" "Unknown Device"
Does the mouse and/or keyboard have a "connect" button on the bottom of either? Try restarting your PC, then, if you have installed new batteries, and the mouse/keyboard is still not connected, try the "Connect" button if any.
Jan 01, 2010 | GE Wireless Optical Mouse
Wireless optical mouse #97990 Rev 5 does not work
Remove the batteries. Remove the receiver from the PC. Reinsert and try to link them again.
Aug 31, 2009 | GE Wireless Optical Mouse
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse thinks its alive (GE wireless optical 97990 rev.4)
Could be signal interference or overloaded usb port. Move receiver around to get a more direct signal, and notice any other devices in use like phones. Use alone without other usb devices plugged in and/or buy usb hub with power adapter. DO NOT buy passive usb hub with no additional power.
Nov 18, 2008 | GE Wireless Optical Mouse
New mouse, still has problems
Some mice eat batteries like they are nothing. I myself have a logitec wireless mouse and i must replace the batteries every two weeks. I would suggest getting another mouse.
May 24, 2007 | GE Wireless Optical Mouse
GE Wireless mouse 97990 Rev 4 stopped working
From the Jasco website, some other options to try: Batteries: Tracking can be affected by low or dead batteries. Try replacing the batteries with a fresh set and test the tracking. Although you can use rechargeable batteries, alkaline batteries have been found to have the longest battery life. Interference with other electrical products: Other electrical devices may interfere with the radio signal that the mouse uses to communicate with the receiver. Try placing the receiver in a different location, away from the monitor, zip drives, and other electrical devices. Also, try rotating the receiver so it is on its side (or back). Range of the receiver: GE cordless pointing devices can transmit a signal up to 2 meters (appr 6 ft). Make sure the receiver and mouse are within the 2 meters of each other.
Dec 20, 2006 | GE Wireless Optical Mouse
GE Wireless Optical Mouse Logo
383 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
