Question about Remington 109312 - 01 Garden Wizard Electric Tiller
Remington electric tiller circuit breaker goes off
My Remington garden wizard electric tiller shuts off and circuit breaker releases after a few minutes of running time. Could the problem be my extension cord not rated at high enough amps? I am using a 16 or 14 gauge cord. Do I need a more heavy duty cord?...thanks, Jim
For about $20.00 you can buy 50 feet of 12 guage 3 wire yellow extention cord. You will then get all the amps you need to run your unit. If it still fails, you have a problem inside the tiller.
Tom MN
Posted on Jul 14, 2009
  • 137 Answers
If your extension cord is very long the I would suggest a 12 gauge wire, you should not run a devise like this with less than a 14 gauge cord. Touch the cord you are using if it is warm or hot this is no doubt your problem.
Posted on Jan 30, 2009
Kitchenaid electric oven goes on by itself,no error code
Go to the electrical department of your local home repair store and buy an electrical circuit tester. They look like a plug and have three lights on them some have the three lights and a small button to test gfci circuits. plug it into the 110 outlet and check if it is wired correctly. If this is a 220 circuit disregard and give me more information
Oct 09, 2014 | KitchenAid KESC307 Electric Kitchen Range
Snow joe tiller does not run
Have you tried to reset the circuit breaker on the tiller?
Mar 14, 2014 | Snow Joe Sun Joe Tiller Joe Max 9 AMP...
How do i install the tines?
Did you get a picture?
Where did you get the tines? I'm looking for replacement tines but not having any luck.
Mar 04, 2012 | Remington 109312 - 01 Garden Wizard...
Where can I get brushes and at what cost?
Parts for Remington saws are few and far between. Brushes are a common failure point and those available have about been bought up. You best chance is to check with a well-stocked hardware store or an electric tool repair shop for a similar brush from a different tool. You may have to modify something similar to fit. Good luck!
Dec 11, 2010 | Remington 111409 - 01 6" Branch Wizard...
My electric remington pole saw seems to have no power. Just had a new chain put on it but when I went to use I get no vibration or movement of any kind...just plain dead. Don't seem to have any places in...
Did you try a different outlet (circuit breaker) and extension cord? if those are good logical choices are brushes (NLA) or field windings (also NLA on most models) Remington is no longer in production and odds are very good replacement parts would not be available even if you found a repair shop. Sorry.
May I recommend a name brand replacement? Someone you expect to be in business for the next ten years. Often additional cost is defrayed by many fewer replacement parts over the life of the product.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 28, 2010 | Remington Polesaw Wizard
Looking for owners manual
I have a manual for the Wizard 5HP tiller. The reverse belt basically makes a figure 8
The belt goes over the motor pulley and over the idler pulley then makes a twist in the middle and around the bottom pulley. This cause it to basically rotate the opposite direction from the rotation of the drive pulley
Apr 05, 2009 | Garden
Remington 109312 - 01 Garden Wizard Electric Tiller Logo
413 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
