Question about HP Deskjet 5440 InkJet Photo Printer
Tells me incorrect print cartridge(s)
I know the cartridge's are the correct ones. How do I correct the settings or the problen. I have uninstaled and reinstaled. That didn't fix.
  • Anonymous Feb 16, 2009
    i got my comp fixed and they uninstalled my printer so when i reinstalled it, it some how chenged the setting so now my color printer only now prints in black and white and i dont know how to fix it :(
    Sergeant:
  • 359 Answers
Are you sure you removed all the tear away clear plastic from the new cartridge before install as this will cause this check it
Posted on Jan 30, 2009
Print cartridge incorrectly installed
Double check the install (yes I know you have, but try again) and also try another cartridge, it may be the circuit board on the cartridge that is giving the problem, not the printer.
Nov 01, 2016 | Office Equipment & Supplies
Lights flashing says print head is incorrect,install correct print head,but it was the same print head,it just appear..canon pixus mp 600,what can I do plse
Hi. Unplug the printer from its power and try this.1. Pull the cartridges out 2. Remove the print head, and re-install making sure the metal contacts on the side line up with the ones in the printer. it can appear to be in OK but use a strong light to make sure it is lined up correctly. 3. Re-Install the cartridges and try again.
This can also happen with some compatible cartridges or ones that have been re-filled and re-set too many times. The black cartridge is usually the issue in this case.
I hope this helps Regards GM
Apr 10, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Error: right cartridge incorrect
Left Cartridge Incorrect / Right Cartridge Incorrect
  1. Remove the indicated print cartridge.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
  5. Reinsert the print cartridge.
  6. If the error:
    • Does not reappear, the problem has been corrected.
    • Reappears, replace the print cartridge with a new one.
Jul 19, 2010 | HP PSC 2210 All-In-One InkJet Printer
The type of print head is incorrect. Install the
yes . put exactly the cartridge that is compatible with your printer , make sure that you are replacing with the one that has the same number on it as that of the previous cartridge
Jul 07, 2010 | Canon Pixma MP500 All-In-One InkJet...
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
I have a Lexmark X3430
the cartidge that you have just refilled is not filled correctly.
May 29, 2009 | Lexmark X2500 All-In-One Printer
Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Jan 14, 2008 | Brother HL-2040 Laser Printer
Hp psc 2110 incorrect ink cartridge message.
when ever i get that message it's when i use a "Non-HP" replacement cartridge...try using a HP catridge, or most likely, the printer has reached the end of it's usefull life!
you can try a "full reset" of the printer by..
-unplug it and let sit for a little while,
-BEFORE plugging it back in, press and hold both the enter and cancel buttons,
-plug the power cord in, and wait to release the buttons until the display on the printer tells you to,
-in many cases, this corrects some problems (especially that awfull grinding/ratcheting noise).
after many years of faithful service, i think mine is officially dead though...even the full resxet doesnt help.
Oct 26, 2006 | HP PSC 2110 Color Printer
HP Deskjet 5440 InkJet Photo Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
