Question about GE WJRR4170E Top Load Washer
Agitator is slipping- GE model WJRR4170G top load washer
I have a GE model WJRR417G top loading washing machine, and it appears and sounds like the agitator is slipping while in use. I cannot figure out how to remove the agitator to inspect. I have taken the fabric softener resivour off, and now I am stuck. Any info would be a huge help.
  • etnivin Jan 30, 2009
    How do I get that cover cap off? Do I need a special tool?
    It appears That the agitator is slipping. Where is the lint filter located, and why would it be chattering? Dirty?
    Problem Solver:
  • 6 Answers
IF the agitator is like the ones in the older models, it will just pull straight up and off of the transmission shaft.
Inside the agitator there is a rubber splined insert with an aluminum center. The soft aluminum strips out causing the grinding sound. Very common to happen.
We used to use a special puller to remove that part and then press a new one back in.
Voila! Repaired agitator!!
Most any appliance parts store should be able to look up your model # and tell you if that agitator can be resplined.
Posted on Feb 20, 2009
  • 15,935 Answers
That is a good start!!
Under the F/S cup is a bolt.... down inside the agitator.
Once this is out, the agitator will lift out.
See THIS LINK
It is of a whirlpool, however it should be close!!
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Jan 30, 2009
    President:
  • 2,976 Answers
Is the agitator actually slipping, or could you be hearing the lint filter chattering?
    President:
  • 1,214 Answers
Starting at the center agitator stem, there should be a cover cap or something that is removed to allow access to the bolt or nut that hold the agitator on.
Reply back what you find and I'll help further.
  • Mark Egan Jan 30, 2009
    No. It will either pop off, or it will unscrew. Use one of those rubber jar openers to get a good grab on it.
2 Suggested Answers
SOURCE: agitator is slipping
I have a different model, but my agitator came off with brute force. I used 2 allen wrenches in the slots on the side of the agitator to get leverage and then yanked until it came off. The problem is your air bell coupler.
Posted on Feb 02, 2009
The washer does not spin during the spin cycle. The motor appears to be working for the agitator.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2010 | GE WBSR3140DW Top Load Washer
The plastic agitator isnt spinning it sounds as though the piece it sits on is turning but just spinning insde the plastic housing on the underside of the agitator
your "agitator coupling" is worn out underneath the agitator,remove the dispenser cup on t6he agitator,then the agitator,it sits on the coupler on splines and they wear out and the agitator can,t grip them anymore and slip
May 14, 2010 | GE WBSR3140DW Top Load Washer
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Tub will spin but agitator won't move on my ge washer model wpsr3090v0ww
IF it sounds like it is agitating but isn't moving, check to be sure the agitator is still firmly bolted to the transmission shaft. If it sounds like it's stuck when it tries to agitate (belt slipping possibly, etc.) it is probably a bad transmission and often not worth repairing unless you can find a used one somewhere.
Dec 31, 2009 | GE WBSR3140DW Top Load Washer
The agitator makes a grinding sound evan when you
this probem is caused by defective bearings, u will need to pull the washer apart and have the bearing checked by a professional for excessive wear, one of them is worn, most likely the agitator shaft bearing. i will advise u that the cost of repair may exceed the cost of a new washer. here is the basic instructions for teardown. go to the link.
http://fixitnow.com/wp/2007/11/26/replacing-the-transmission-in-a-ge-top-loading-washing-machine/
Oct 19, 2009 | GE WBSR3140DW Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
May 28, 2009 | GE WBSR3140DW Top Load Washer
Jan 30, 2009 | GE WJRR4170E Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
GE topload washer Agitator
theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Dec 03, 2008 | GE WBSR3140DW Top Load Washer
GE WJRR4170E Top Load Washer Logo
706 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
