Question about Linksys Wireless-G Broadband Router
Linksys wireless was fine on my lan line now cable it is not?
Roadrunner cable said I need a password for static ip address, a dinamic ip address to get linskys wireless to run on cable hook up. How do I get it and put it on my pc? Linksys model no BEFW11S4
  • 1 more comment
  • nwiater Jan 30, 2009
    yes I am saying it worked on my lan line and now not on road runner.
  • nwiater Jan 31, 2009
    I did the above and the DHCP address is there but still can not use wireless linksys below is my dianostic on my pc:
    Last diagnostic run time: 01/30/09 20:52:08
    Network Adapter Diagnostic
    Network location detection
    info
    Using home Internet connection
    Network adapter identification
    info
    Network connection: Name=Local Area Connection, Device=Intel(R) PRO/1000 PL Network Connection, MediaType=LAN, SubMediaType=LAN
    info
    Network connection: Name=Wireless Network Connection, Device=Intel(R) PRO/Wireless 3945ABG Network Connection, MediaType=LAN, SubMediaType=WIRELESS
    info
    Network connection: Name=1394 Connection, Device=1394 Net Adapter, MediaType=LAN, SubMediaType=1394
    info
    Network connection: Name=Local Area Connection 3, Device=Bluetooth LAN Access Server Driver, MediaType=LAN, SubMediaType=LAN
    warn
    This machine has more than one Ethernet or more than one Wireless adapter
    info
    Redirecting user to support call
    HTTP, HTTPS, FTP Diagnostic
    HTTP, HTTPS, FTP connectivity
    warn
    HTTP: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
    warn
    HTTPS: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
    warn
    FTP (Passive): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
    warn
    HTTP: Error 12007 connecting to www.hotmail.com: The server name or address could not be resolved
    warn
    HTTPS: Error 12007 connecting to www.passport.net: The server name or address could not be resolved
    error
    Could not make an HTTP connection.
    error
    Could not make an HTTPS connection.
    error
    Could not make an FTP connection.
  • EricDaniels
    EricDaniels May 11, 2010
    So your saying you used to use an static ip address prior to getting service with Roadrunner? You probably need to setup your DHCP on your router so it can request a Dynamic IP from Roadrunner servers. Just clarify with me or start up a live chat.
  • 80 Answers
Lets see if this works out for ya.
1. In your browser go to http://192.168.1.1
2. The user will be "admin" and the password field leave it blank
3. Go to the Setup Tab
4. On WAN Connection Type make sure it is set to "Obtain an IP Automatically"
5. Go to the DHCP tab and make sure it is enabled
6. Unplug the Roadrunner modem and the Linksys Router.
7. Wait around 15-30 seconds
8. Plug the Roadrunner modem in and wait until all the lights except the ethernet/computer connection are on.
9. When they are all on plug the Linksys router power back in
10. Wait around 30 seconds and see if your getting a connection
Otherwise get back to me. Good luck.
Posted on Jan 30, 2009
How can I make settings to support DHCP IP assignments and also recognize my manual IP's assigned to the LAN connected devices?
The easiest way I can think of is to shrink the DHCP address pool.
To do that, at least on the model of Actiontec router I have, click on "Network (Home/Office)" the go to the "IP Address Distribution" section of the screen. "DHCP Server" should already be selected, and under that, you'll find "Start IP addresses" and "End IP addresses." Usually, the start will be 192.168.1.2 and the end will be 192.168.1.254. What I usually do is change the start address to 192.168.1.200. That leaves over 50 addresses for normal wireless connections, and I'll general assign IP addresses from the rest of the range as follows:
192.168.1.2 to 192.168.1.9: routers, APs, etc.
192.168.1.50 to 192.168.1.59: printers
192.168.1.100 to 192.168.1.109 for other static devices. (I often find that Blu-Ray players, cable boxes, etc. behave better if they have a static address.)
But really, on home network, I doubt you'll have more than 15 devices that need static addresses, so you could set the DHCP start address as low as 192.168.1.16 if you wanted to.
Sep 17, 2015 | Linksys Computers & Internet
Need help setting up the Sudenlink Modem to Linksys Router
Connect lan cable from modem to linksys router's WAN port.
Then configure linksys router with below method.
Yes you need wireless router to use wifi in ipod touch or on laptop.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method.
Then click on WAN settings set as your internet service provider settings like static ip address.If service provider give you user and password for connect internet then set router in pppoe mode.
Enable DHCP.
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 18, 2011 | Linksys WRT160N Wireless Router
I want to change the channel my Linksys is using. So I went to Internet Browser and typed in my IP address. It said I need a Username and Password. Where would I find that.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . If you are not able to access router with above user and password then yo need to reset it. For that press RESET button for 10 seconds it is in back side of router.Then configure it again with above method.
Dec 05, 2010 | Linksys Wireless-G WRT54G Router
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Well my problem is really a network problem, before i was able to surf the net and stay online on my console. But in the past week i am not able to, my console (360) says that my network router is not...
To check your Linksys wireless router settings, open IE browser and type in the Linksys configuration IP address http://192.168.1.1
and login = admin and the PW = admin (if you didn't change the default password) - The default password should be changes to stop unauthorized access into the Linksys router.
If you cannot get into the Linksys router configuration wirelessly, then you need to connect a LAN cable from the computer to the Linksys router.
Check the DHCP and wireless settings. Take a note of the wireless settings (ie SSID, encryption etc.) and check the wireless card setting in the computer, it needs to have these settings for the wireless/LAN to connect to the Linksys router. The TCP/IP settings on the LAN?wireless cards needs to have Obtain IP address automatically and Obtain DNS server address automatically.
Nov 10, 2009 | Linksys Wireless-G WRT54G Router
Cant Access wet200 setup page ive changed my static ip still wont
Connect a LAN cable from your computer to the Linksys wireless router.
Setup a static IP subnet on your computer ip 192.168.1.xxx
make xxx= 20
Start your IE browser and type
http://192.168.1.226
Login as admin with a password admin
You can now configure the Linksys.
If you need a manual then click on this link to download the manual :-
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Sep 19, 2009 | Linksys WET200 802.11b/g Wireless Bridge
Linsky worked on Lan Line now I have Cable
Dynamic ip address is provided automatically by your internet service provider..
inorder for the linksys to work you need to remove the old configuration from the linksys.
you need to reset the router,look at back of the router you will see a hole which says reset
you need somethihg pointed like a paper clip or pin to hold it down for about 30 secs,then power off the router wiat for a minute and then power on the router,
now your linksys router should be able to take the dynamic ip address from you internet service provider.
Jan 30, 2009 | Linksys Wireless-G Broadband Router
Logged off
The LAN should not ever log off but either you are talking about the Internet, which can, microwave devices (ovens, wireless phones) that intermittently interfere or dynamic ip addressing cycles that assign you the 169.xxx.xx.x from within Windows attention deficit disorder manager. You can assure static assignments of ip addresses for your LAN (write down the ip address and default gateway when you are logged on to see what they should be) or log on to your router (Start>Run> type http://192.168.1.1 for Linksys, user name linksys, password is admin and you can configure your LAN and WAN. Select DHCP for cable modems, PPPoE for DSL or STATIC for ensuring LAN ip address assignments. ~Steve
Oct 17, 2008 | Linksys WUSB100 Wireless Adapter
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Linksys Wireless-G Broadband Router Logo
135 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
