Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Had camera in purse?!?!
I had my camera in my purse in a seperate pocket, but it still is quite a flimsy purse and I had not got it out in a good couple of weeks, and I got it out to take some pictures. I turned it on and the lcd screen was all bright light with purple leaf fike lines coming douwn from one corner. I think the screen was poked buy one of the pens I carry in my purse. Is there anything I can do or do I have to buy another camera cuz this one is toast. I mean the camera still turns on and the lens still comes out but I can't see any pictures on the screen like before and it will even act like it is taking pictures. PLEASE tell me there is something I can do!!?
You can buy a new screen and have that installed but it will be at least 60 bucks... check out ebay
Posted on Oct 10, 2007
My item I am disappointed with the quality of the item. The catch on the purse does not stay shut.
contact the seller and request a refund for the purchase. State a reason of unfit for the purpose or faulty workmanship or faulty product. If you bought it through paypal then notify them of the product fault and that you have requested a refund. If you get no satisfaction then contact your state small business organization and lodge a complaint.
Jan 13, 2015 | Cars & Trucks
Tip
Lense sticking with good battery?
If you have a Kodak EasyShare V603 and have the lense sticking or not retracting all the way when you power down with a known good battery, this tip may save the day for you ...
Note I said MAY save the day, NOT "will" ... Nothing in life is certain ...
The extending/retracting lense assembly is very sensitive to dust or foreign material. If even the slightest amount of dust... pocket lint, anyone?... gets inside the camera housing in the area of the lense mechanism, the sticking can occur...
the solution is to undo the screws holding on the front half of the housing and get that shell out of the way... then run a clean q-tip around the outer rim of the lense assembly ...
filthy, isn't it? ... now repeat... once your q-tip comes up clean, blow away any residual dust. The jury is out on whether alcohol helps at all here ...
Repeat the procedure to clean the opening in the camera housing through which the lense extends as well ...
Reassemble the housing and you MIGHT be good to go ...
Of course, if you dropped the camera into the La Brea Tar Pits, don't expect a miracle, but this procedure can get rid of a surprising amount of dirt & dust that can build up inside the camera from carrying it in your pocket or purse ...
I DID say you need a known good battery, right ? oh, and it helps if it is fully charged too ...
Worked for me !
on Feb 02, 2012 | Kodak EasyShare V603 Digital Camera
Tip
A tip and suggestion on using any digital camera.
One of the most two important tips in my experience with digital cameras and the use of them is in the following.
When using a digital camera always take the time to put the hand cord on your wrist. This will help to insure that the camera will not be dropped when using any where, including over or near water. By the way, using any digital camera near water should be done carefully. Water is extremely damaging to the delicate internal parts.
When the digital camera is not in use, always be sure to put the camera in a padded case. I know that it takes more time than dropping into a purse or pocket, but if you take the extra time, you will enjoy your digital camera a lot longer.
By dropping a camera into a purse, you will take the chance of the unit being damaged by other items and possibly turning on from pressure of some item on the on button. This can cause the camera's lens to extend and since it is in a compact area, it can become damaged.
By putting the digital camera into a pocket, you take the chance of the camera falling out and being damaged. It is surprising how many cameras I have had which have been dropped and damaged.
on Dec 18, 2009 | Cameras
My lens is stuck out and it will no longer take pictures. It is brand new!
The lens has either been hit, dropped against something, or the camera allowed to turn on while in a pocket/purse/case. The lense drive gears are plastic and not entirely substantial and require care - which most people especially teens and 20's don't give them. Once in this condition, they're done for. You can attempt to contact Fuji for repair, but you'd be responsible for the cost unless they're feeling especially nice that day, since there's simply no way for the lense to become jammed during normal operation - unless the lens is bumped or hit while open.
Since these camera require total disassembly, from the back forward, to get to the lense assembly, it'll be cheaper or near it to replace it than to repair it. Take it as lesson learned, and treat the next one with more care. NEVER touch the lense when open, NEVER allow it to bump anything, NEVER drop it, NEVER place it in your pocket or purse unless the power button is protected from being accidentally turned on.
Aug 22, 2011 | Fuji Photography
I had my camera in my purse and when i took it out and turn it on. my camera turns on white screen but with a black liquid spot on it. is it fixable? please help my camera is brand new.
Your purse would have happened to be black and the camera on the outside pocket would it?
If so and it was in heat then the LCD screen has super heated, it might come back after a few hours to cool. There is operating temperature ranges listed in the manual extreme heat and cold will just kill most digital point and shoot type cameras, sometimes they come back sometimes not.
I would also take the battery out of it and let it sit for a few hours to cool DON'T put it in a cold place let it come up to room temperature gradually.
Apr 12, 2011 | Cameras
My Samsung es 65 digital camera's LCD blacked out after charging. What could be wrong?
What a misery! You are using your cell phone every day,
pushing it in your pockets, swapping your bags, content and purses and for
years it will do just everything you like or what it is designed for. Probably
product testing makes this item fit for such actions.
Samsung cameras react quiet a bit different! Treat them with
outmost respect and fragility and a month after purchase the LCD screen will
quit. Samsung explains that mistreatment would be the cause of it and the cost
of repair would amount to near the purchasing cost of the item! Google the
internet for "Samsung LCD screen not working" to make up your mind.
Samsungs whole product line seems to be crashing out on the
same issue. Is it worth to loose your money for bad product design?
Dec 18, 2010 | Samsung Battery Battery Charger for BP70A...
Power button does not work
This company can repair this problem and will also do a cleaning as part of it. A lot of time all the dirt that the camera picks up works its way into the crevices of the camera and starts showing these problems.
https://www.teleplancamerarepair.com/quote/cart.asp?iProbID=21&mo=15
they also do a full cleaning which should prevent any additional problems. once it is repaired, if you plan to have it in a pocket or purse it is always good to have it inside a protection, while these still have dust, it is far less than rolling around in a back pack or purse.
Jul 16, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My phone takes pictures, by itself, when it's closed. Make it Stoooooooooop!!
Unfortunately, on that model there is not an option to lock your side keys. (and one of your side keys is a camera key) Your best bet is to buy a case and keep it in that while it's in your pocket or purse.
Rate My Answer!
Wendy......
Nov 20, 2009 | Samsung SCH-u340 Cellular Phone
Lens stuck in out position
Try this...the camera will not work as it is...so try this one.
As you turn on the camera, hold the lens back by putting pressure on it...this may reset the camera lens back to the right position.
Your problem seems to be that the camera lens is out of sync with the rest of the camera system.
Try the above a few times... I had a camera which did the same thing, and by holding back (you can also try to pull on the lens) on the lens as it was turned on, it reset itself....May be worth a try. Be careful, because you can damage the lens with this process.
If the small gears in the lens are broken, then it will not work, and may cause more damage.
The lens is a very delicate mechanism and can be damaged by having it turn on in a crowded area such as a pocket, purse, and so on.
I always say... Treat the camera like eggs and unless there is a failure of electronics or mechanical problem, it will last a long time. Use a soft padded case, and treat the camera like a jewel, and it will give good service.
Too many people treat the digital cameras like they are made very strong by putting them in pockets, purses, crowded areas of other kinds. That will almost insure damage at some time. The LCDs in most digital cameras are easily damaged by slight pressure. The lens as well can be damaged beyond repair by dropping (hold the camera always with the wrist strap), bumping it against a hard object and so on.
Jun 25, 2008 | Pentax Optio M20 Digital Camera
Motorola cell
have you tried the faqs.from here http://motorola.com/consumer/v/index.jsp?vgnextoid=06e1dd9fc0e2b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00002&show=globalSupport&productID=48bfe2f9eb3d9010VgnVCM1000008206b00aRCRD
riz.
Nov 01, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
